Other Parts Discussed in Thread: HALCOGEN, LAUNCHXL2-RM57L
Hi all,
Is there a pinout for the Launchpad XL2 TMS570 board, relating board pins to proc pins?
Looking at the schematic is not as helpful as I thought it would be.
Hi all,
David,
I think I might understand your question. It's a bit difficult sometimes to answer the question 'how should I set the pinmux to output signal "N2HET1[x]" onto board pin 'Jy-z'.
This is because the N2HET signal may appear on multiple balls and you really need to know which BALL (like "C3") in order to find the right row to click on in the HalCoGen pinmux table.
I did something like this for myself recently for a particular HET program by reading in the LAUNCHXL2-RM57L netlist into HalCoGen then extracting the mapping
of BALL # to Jx-Y pin # into a table. I don't think it's ready to 'give out' because I did it specifically for a particular design but I think it may be what you want.
If it is - then maybe we should clean this up and post it.
But - the info can definitely be extracted easily from the Eagle netlist.
Anthony
