tm4c1294ncpdt vs tm4c129xnczad-iot application
Expert 1255 points
Other Parts Discussed in Thread: EK-TM4C1294XL, TM4C129XNCZAD, TM4C1294NCPDT, EK-TM4C129EXL, TM4C129ENCPDT
hi,
I feel that ek-tm4c1294xl is more used compared to dk-tm4c129x.
The major difference is in the mcu involved.
The cost factor aside, tm4c129xnczad has crypto hardware accelerators and  tm4c1294ncpdt doesn't.
I am building an iot application, would this security aspect play a key role? Or would it suffice if i used tm4c1294ncpdt ?
av
  • I guess you need to answer this question yourself.
    If you want/need to hide application specifics, or want/need restrict access to your application, and missing hardware support for en/decryption breaks your application (performance-wise), then the more expensive MCU is indicated.
    I am building an iot application, ...
    IOT is on of the currently most popular buzzwords. Others might disagree, but I don't want my coffee machine, fridge, or water meter to share my private information in an uncontrolled and uncontrollable fashion. Just my personal opinion.
  • Apart from the DK-TM4C129X board, the EK-TM4C129EXL LaunchPad (which has the TM4C129ENCPDT device) also has the Crypto hardware accelerators available. All the other peripherals are exactly same as the EK-TM4C1294XL LaunchPad.
    Sai
