- Who has RM57L843+lwip+IAR project can be referred by me? Would you please send to me?
- Because 003 example is in CCS project. My project is in IAR tool. And I found there is big different between CCS and IAR using HAL Code Gen generation.
Yes, I saw the data telegram flow(contain ARP/ICMP request and response) by CCS, but don't capture by IAR.
So you should compare side by side if possible.
Try comparing the registers of the EMAC and also the registers of the PHY (through the MDIO interface) to find out what the differences are.
You should be able to find some difference and then following up on what this is will likely lead to the answer.
