Other Parts Discussed in Thread: HALCOGEN, TMS570LS3137, DP83640
I have tested ethernet with MII and works fine.
Now I am trying a new board with RMII and does not seem to talk over ETHERNET at all
the RMII clock input is changed 50Mhz
the pin muxing and RMII setup was done using halcogen 04 05 02 - the rest of the code is exactly what I had working on my MII board
it appears that the files that changed are pinmux.c/.h emac./.h
VCLKA4 is set to 40mhz
anything else has to be done to get RMII to work - the boards were built last week so they are using latest silicon
