Other Parts Discussed in Thread: HALCOGEN
can somebody settle an argument please.
We are using the TMS570LS04 and we want to use the hetPort as GIO, but not use the het module. To drive the hetport we need the defines in reg_het.h and het.h. It has been found that these files are generated by HalCoGen regardless of whether the Het driver is enabled (in the Driver Enable tab) and the Peripheral Enable is enable (in PinMux).
One engineer says that this is a fluke and shouldn't be relied upon and the driver should always be enabled, regardless of the unused code that is generated (het.c)
The other engineer says that this isn't a fluke, it's deliberate so that the hetport can be driven as GIO without the Het being activated and we shouldn't generate unnecessary code.
Who is right?
Andy
