problem with leds in rm57lx
i have a problem with the debug
Error connecting to the target:
(Error -600 @ 0x0)
A required dynamic library could not be located.
The library isn't on the search path.
(Emulation package 6.0.222.0)
and this
IcePick: Error connecting to the target: (Error -600 @ 0x0) A required dynamic library could not be located. The library isn't on the search path. (Emulation package 6.0.222.0)
/** @file HL_sys_main.c
*   @brief Application main file
*   @date 02-Mar-2016
*   @version 04.05.02
*   This file contains an empty main function,
*   which can be used for the application.
* Copyright (C) 2009-2016 Texas Instruments Incorporated - www.ti.com
*  Redistribution and use in source and binary forms, with or without
*  modification, are permitted provided that the following conditions
*  are met:
*    Redistributions of source code must retain the above copyright
*    Redistributions in binary form must reproduce the above copyright
*    documentation and/or other materials provided with the
*    distribution.
*    Neither the name of Texas Instruments Incorporated nor the names of
*  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
*  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
*  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
*  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
*  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
*  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
*  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
*  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
*  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
*  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
*  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* USER CODE BEGIN (0) */
/* USER CODE END */
/* Include Files */
#include "HL_sys_common.h"
/* USER CODE BEGIN (1) */
#include "HL_gio.h"
/* USER CODE END */
/** @fn void main(void)
*   @brief Application main function
*   @note This function is empty by default.
*   This function is called after startup.
*   The user can use this function to implement the application.
/* USER CODE BEGIN (2) */
#define DELAY_VALUE 1000000
/* USER CODE END */
void main(void)
/* USER CODE BEGIN (3) */
	int i;
		gioInit();
		for (;;) {
			gioToggleBit(gioPORTB, 6);
			for (i = 0; i < DELAY_VALUE; i++);
/* USER CODE END */
/* USER CODE BEGIN (4) */
/* USER CODE END */
