Other Parts Discussed in Thread: TMS570LS1227
Hello!
We have designed a custom board for the TMS570LS1227. We also have two different chips available: TMS570LS1227BPGE and TMS570LS1227CPGE.
After assembly of the PCB, using a rev. C device, I encountered some errors, wich made me suspect that the microcontroller is faulty (overheated during soldering, ESD damage). The nERROR pin was low, although the quartz oscillator worked. After this I replaced it with a rev. B device and it worked, the nERROR pin was also high.
I repeated the process on another board with the same results: rev. B worked, rev. C didn't. Could someone please explain the difference? I have read the silicon errata for the device and haven't found anything relevant.
Here you can find the schematic for this fairly simple board. I also would like to ask if the JTAG connection is making correct use of termination and pull up and pull down resistors.7607.Stamp_TI_2017.pdf
Thank you!
Peter
