I was successful in using dht-11 sensor with tm4c129, but when i tried the same code on tm4c123 it entered in infinite loop. I think the problem is due to the clock because, the other part of the code is the same.
I am using sysctlclock freqset((sysctl_xtal_25Mhz | sysctl_osc_main| sysctl_use pll | sysctl_cfg_vco480), 40000000);on TM4C129 this is giving me clk frq of 40Mhz.
SysCtlClockSet(SYSCTL_SYSDIV_5| SYSCTL_USE_PLL | SYSCTL_OSC_MAIN |SYSCTL_XTAL_16MHZ); on TM4C123 this gives me frq of 40Mhz when i do syscltclockget();
I still dont get value on TM4C123. what might be the reason? is it due to the vco?
How to get similar functionality like sysctlclock freqset using SysCtlClockSet?
