Other Parts Discussed in Thread: TPS2052B, TPS2052
Hello Amit,
My design calls for powering a target using OUT2 of the TPS2052B regulator. The target, a damaged memory card, could 1. draw too much current or 2. be shorted to ground.
I'm attempting to use PQ4 in interrupt mode to indicate either of these conditions thereby disabling (EN2) the regulator.
Is enabling the regulator then shorting X11-60 to ground an appropriate test. Currently it appears to be resetting the EK board.
Thank you,
Victor
