TM4C123 RTC DriverLib
Hello, how to read the RTC counter value in TM4C123G using the timer driver library since there is no API referring to it ?
Thank you
  • Hello Ahmed
    To us the Timer in RTC mode, you would need to provide a 32KHz clock on the CCP pin. The next thing you would need to do is to configure the timer using TimerConfigure API call with the mode set as TIMER_CFG_RTC in full width mode.
    You can check the timer.h for the API for setting the Timer Match in RTC.
