Part Number: TMS570LC4357
Other Parts Discussed in Thread: HALCOGEN
I'm trying to run simple program with gpio interrupt, but processor jumps to invalid address in reset vector.
I put breakpoints from 0x04 to 0x1c. When I push the button -> core immediately jumps to 0x08 instead to 0x18.
Because of breakepoints I can see vim registers and they look fine to me except one:
IrqVecReg contains 0x541 and that is my phantomInterrupt_handler address. Despite the fact that 23th word from address 0xFFF820000 (ISR) contains 0xb69 and that is correct gpioInterrupt_Handler.
Why core jumps to SoftwareInterrupt?
I'm including list of vim registers and screenshoot of paused program and memory view on ISR.
Vim
IrqIVec 0x00000018 Index Offset Vector Register [Memory Mapped]
FiqIVec 0x00000000 Index Offset Vector Register [Memory Mapped]
FIrqPr0 0x00000003 Program Control Register [Memory Mapped]
FIrqPr1 0x00000000 Program Control Register [Memory Mapped]
FIrqPr2 0x00000000 Program Control Register [Memory Mapped]
FIrqPr3 0x00000000 Program Control Register [Memory Mapped]
IntReq0 0x00800000 Pending Interrupt Read Location [Memory Mapped]
IntReq1 0x00000000 Pending Interrupt Read Location [Memory Mapped]
IntReq2 0x00000000 Pending Interrupt Read Location [Memory Mapped]
IntReq3 0x00000000 Pending Interrupt Read Location [Memory Mapped]
ReqMaskSet0 0x00800203 Interrupt Mask Set Register [Memory Mapped]
ReqMaskSet1 0x00000000 Interrupt Mask Set Register [Memory Mapped]
ReqMaskSet2 0x00000000 Interrupt Mask Set Register [Memory Mapped]
ReqMaskSet3 0x00000000 Interrupt Mask Set Register [Memory Mapped]
ReqMaskClr0 0x00800203 Interrupt Mask Clear Register [Memory Mapped]
ReqMaskClr1 0x00000000 Interrupt Mask Clear Register [Memory Mapped]
ReqMaskClr2 0x00000000 Interrupt Mask Clear Register [Memory Mapped]
ReqMaskClr3 0x00000000 Interrupt Mask Clear Register [Memory Mapped]
WakeMaskSet0 0xFFFFFFFF Wake-up Mask Set Register [Memory Mapped]
WakeMaskSet1 0xFFFFFFFF Wake-up Mask Set Register [Memory Mapped]
WakeMaskSet2 0xFFFFFFFF Wake-up Mask Set Register [Memory Mapped]
WakeMaskSet3 0xFFFFFFFF Wake-up Mask Set Register [Memory Mapped]
WakeMaskClr0 0xFFFFFFFF Wake-up Mask Clear Register [Memory Mapped]
WakeMaskClr1 0xFFFFFFFF Wake-up Mask Clear Register [Memory Mapped]
WakeMaskClr2 0xFFFFFFFF Wake-up Mask Clear Register [Memory Mapped]
WakeMaskClr3 0xFFFFFFFF Wake-up Mask Clear Register [Memory Mapped]
IrqVecReg 0x00000541 Irq Interrupt Vector Register [Memory Mapped]
FiqVecReg 0x00000541 Fiq Interrupt Vector Register [Memory Mapped]
CapEvtSrc 0x00000000 Capture Event register [Memory Mapped]
ChanCtrl0 0x00010203 Channel Mapping Register [Memory Mapped]
ChanCtrl1 0x04050607 Channel Mapping Register [Memory Mapped]
ChanCtrl2 0x08090A0B Channel Mapping Register [Memory Mapped]
ChanCtrl3 0x0C0D0E0F Channel Mapping Register [Memory Mapped]
ChanCtrl4 0x10111213 Channel Mapping Register [Memory Mapped]
ChanCtrl5 0x14151617 Channel Mapping Register [Memory Mapped]
ChanCtrl6 0x18191A1B Channel Mapping Register [Memory Mapped]
ChanCtrl7 0x1C1D1E1F Channel Mapping Register [Memory Mapped]
ChanCtrl8 0x20212223 Channel Mapping Register [Memory Mapped]
ChanCtrl9 0x24252627 Channel Mapping Register [Memory Mapped]
ChanCtrl10 0x28292A2B Channel Mapping Register [Memory Mapped]
ChanCtrl11 0x2C2D2E2F Channel Mapping Register [Memory Mapped]
ChanCtrl12 0x30313233 Channel Mapping Register [Memory Mapped]
ChanCtrl13 0x34353637 Channel Mapping Register [Memory Mapped]
ChanCtrl14 0x38393A3B Channel Mapping Register [Memory Mapped]
ChanCtrl15 0x3C3D3E3F Channel Mapping Register [Memory Mapped]
ChanCtrl16 0x40414243 Channel Mapping Register [Memory Mapped]
ChanCtrl17 0x44454647 Channel Mapping Register [Memory Mapped]
ChanCtrl18 0x48494A4B Channel Mapping Register [Memory Mapped]
ChanCtrl19 0x4C4D4E4F Channel Mapping Register [Memory Mapped]
ChanCtrl20 0x50515253 Channel Mapping Register [Memory Mapped]
ChanCtrl21 0x54555657 Channel Mapping Register [Memory Mapped]
ChanCtrl22 0x58595A5B Channel Mapping Register [Memory Mapped]
ChanCtrl23 0x5C5D5E5F Channel Mapping Register [Memory Mapped]
ChanCtrl24 0x60616263 Channel Mapping Register [Memory Mapped]
ChanCtrl25 0x64656667 Channel Mapping Register [Memory Mapped]
ChanCtrl26 0x68696A6B Channel Mapping Register [Memory Mapped]
ChanCtrl27 0x6C6D6E6F Channel Mapping Register [Memory Mapped]
ChanCtrl28 0x70717273 Channel Mapping Register [Memory Mapped]
ChanCtrl29 0x74757677 Channel Mapping Register [Memory Mapped]
ChanCtrl30 0x78797A7B Channel Mapping Register [Memory Mapped]
ChanCtrl31 0x7C7D7E7F Channel Mapping Register [Memory Mapped]
Cp15
CP15_ID_CODE 0x411FC152 MIDR [Core]
CP15_CACHE_TYPE 0x8003C003 CTR [Core]
CP15_TCM_TYPE 0x00010001 TCMTR [Core]
CP15_MPU_TYPE 0x00001000 MPUIR [Core]
CP15_MULTIPROCESSOR_ID 0xC0000000 MPIDR [Core]
CP15_PROCESSOR_FEATURE_0 0x00000131 PFR0 [Core]
CP15_PROCESSOR_FEATURE_1 0x00000001 PFR1 [Core]
CP15_DEBUG_FEATURE_0 0x00010400 DFR0 [Core]
CP15_AUXILIARY_FEATURE_0 0x00000000 ID_AFR0 [Core]
CP15_MEMORY_MODEL_FEATURE_0 0x00210030 ID_MMFR0 [Core]
CP15_MEMORY_MODEL_FEATURE_1 0x00000000 ID_MMFR1 [Core]
CP15_MEMORY_MODEL_FEATURE_2 0x01200000 ID_MMFR2 [Core]
CP15_MEMORY_MODEL_FEATURE_3 0x00000211 ID_MMFR3 [Core]
CP15_INSTRUCTION_SET_ATTRIBUTE_0 0x02101111 ID_ISAR0 [Core]
CP15_INSTRUCTION_SET_ATTRIBUTE_1 0x13112111 ID_ISAR1 [Core]
CP15_INSTRUCTION_SET_ATTRIBUTE_2 0x21232141 ID_ISAR2 [Core]
CP15_INSTRUCTION_SET_ATTRIBUTE_3 0x01112131 ID_ISAR3 [Core]
CP15_INSTRUCTION_SET_ATTRIBUTE_4 0x00010142 ID_ISAR4 [Core]
CP15_INSTRUCTION_SET_ATTRIBUTE_5 0x00000000 ID_ISAR5 [Core]
CP15_CURRENT_CACHE_SIZE_ID 0xF01FE019 CCSIDR [Core]
CP15_CURRENT_CACHE_LEVEL_ID 0x09200003 CLIDR [Core]
CP15_CACHE_SIZE_SELECTION 0x00000000 CSSR [Core]
CP15_SYSTEM_CONTROL 0x8BE50878 SCTLR [Core]
CP15_AUXILIARY_CONTROL 0x00000020 ACTLR [Core]
CP15_COPROCESSOR_ACCESS 0xC0F00000 CPACR [Core]
CP15_DATA_FAULT_STATUS 0x00000000 DFSR [Core]
CP15_INSTRUCTION_FAULT_STATUS 0x00000000 IFSR [Core]
CP15_AUX_DATA_FAULT_STATUS 0x00000000 ADFSR [Core]
CP15_AUX_INSTRUCTION_FAULT_STATUS 0x00000000 AIFSR [Core]
CP15_DATA_FAULT_ADDRESS 0x00000000 DFAR [Core]
CP15_INSTRUCTION_FAULT_ADDRESS 0x00000000 IFAR [Core]
CP15_MPU_REGION_BASE_ADDRESS 0x00000000 Core
CP15_MPU_REGION_SIZE_ENABLE 0x00000000 Core
CP15_MPU_REGION_ACCESS 0x00000000 Core
CP15_MPU_REGION_NUMBER 0x00000000 Core
CP15_TCM_ATCM_REGION 0x00000000 ATCMRR [Core]
CP15_TCM_TCM_SELECTION 0x00000000 TCMSR [Core]
CP15_PERFORMANCE_MONITOR_CONTROL 0x41151800 PMCR [Core]
CP15_COUNT_ENABLE_SET 0x00000000 PMCNTENSET [Core]
CP15_COUNT_ENABLE_CLEAR 0x00000000 PMCNTENCLR [Core]
CP15_OVERFLOW_FLAG_STATUS 0x00000000 PMOVSR [Core]
CP15_SOFTWARE_INCREMENT 0x00000000 PMSWINC [Core]
CP15_COUNTER_SELECTION 0x00000000 PMSELR [Core]
CP15_CYCLE_COUNT 0x00000000 PMCCNTR [Core]
CP15_EVENT_SELECTION 0x00000000 PMXEVTYPER [Core]
CP15_PERFORMANCE_MONITOR_COUNT 0x00000000 PMXEVCNTR [Core]
CP15_USER_ENABLE 0x00000000 PMUSERENR [Core]
CP15_INTERRUPT_ENABLE_SET 0x00000000 PMINTENSET [Core]
CP15_INTERRUPT_ENABLE_CLEAR 0x00000000 PMINTENCLR [Core]
CP15_SLAVE_PORT_CONTROL 0x00000000 AXI Slave Port Control [Core]
CP15_FCSE_PID 0x00000000 FCSEPID [Core]
CP15_CONTEXT_ID 0x00000000 CONTEXTIDR [Core]
CP15_USER_READ_WRITE_THREAD_PROCESS_ID 0x00000000 Core
CP15_USER_READ_ONLY_THREAD_PROCESS_ID 0x00000000 Core
CP15_PRIVILEDGED_ONLY_THREAD_PROCESS_ID 0x00000000 Core
CP15_SECONDARY_AUXILIARY_CONTROL 0x00400000 Core
CP15_NVAL_IRQ_ENABLE_SET 0x00000000 Validation IRQ Enable Set Register [Core]
CP15_NVAL_FIQ_ENABLE_SET 0x00000000 Validation FIQ Enable Set Register [Core]
CP15_NVAL_RESET_ENABLE_SET 0x00000000 Validation Reset Enable Set Register [Core]
CP15_NVAL_DEBUG_REQUEST_ENABLE_SET 0x00000000 Validation Debug Request Enable Set Register [Core]
CP15_NVAL_IRQ_ENABLE_CLEAR 0x00000000 Validation IRQ Enable Clear Register [Core]
CP15_NVAL_FIQ_ENABLE_CLEAR 0x00000000 Validation FIQ Enable Clear Register [Core]
CP15_NVAL_RESET_ENABLE_CLEAR 0x00000000 Validation Reset Enable Clear Register [Core]
CP15_NVAL_DEBUG_REQUEST_ENABLE_CLEAR 0x00000000 Validation Debug Enable Clear Register [Core]
CP15_BUILD_OPTIONS_1 0x00000000 Core
CP15_BUILD_OPTIONS_2 0x403FF9DD Core
CP15_CORRECTABLE_FAULT_LOCATION 0x00000000 Core
PS:
On start I am performing
coreEnableIrqVicOffset:
stmfd sp!, {r0}
mrc p15, #0, r0, c1, c0, #0
orr r0, r0, #0x01000000
mcr p15, #0, r0, c1, c0, #0
ldmfd sp!, {r0}
bx lr
