CCS: unresolved symbol _GPIOPinWrite, first referenced in ./ST7735.obj
I'm trying to compile the example for the ADAFruit ST7735 screen with the TM4C123GXL eval board.
I took it from here:
"github.com/.../examples"
I am getting a linker error of :
I understood that this function should be defined in the driverlib library.
I tried linking the library in the linker options but it didn't help.
Note that I didn't find the tivaware for the TM4C, so I'm using the lib for CM4F:
Lib name: "driverlib-cm4f.lib"
Lib directory: c:\StellarisWare\driverlib\rvmdk-cm4f\
I used it before and it worked, so I'm a bit confused here.
I would appreciate some help with that issue.
Nadav
