Part Number: EK-TM4C123GXL
Other Parts Discussed in Thread: STRIKE
I am chaitanya,
can someone suggest what all types of LCD DISPLAYS are compatible with EK-TM4C123GXL launchpad?
I am chaitanya,
Have you seen the BoosterPack Checker from which you can find display booster packs which are compatible with the EK-TM4C123GXL ?chaitanya kakarla said:can someone suggest what all types of LCD DISPLAYS are compatible with EK-TM4C123GXL launchpad?
E.g.:
Poster Chester can be counted upon to, "Dig for data" and provide a thoughtful reply. And - he's done just that - here.
That said - rather severe limitations are imposed upon ANY USER adopting a, "Display Package" designed to MATE w/a highly specific Eval board. Should the connection points FAIL to mate w/the far more popular LPad - what then? (LPad - by far - is the volume leader!)
And - how possibly could the Display Package designers fully/properly anticipate the signal & functional requirements of SO MANY Users? As a (predictable) result - pins "required" by the user's application may have been (INSTEAD) dedicated to the Display Package - forcing a "witch's brew" of Eval Board "hacks" or (even) eliminating key capability.
Convenience (Plug-In) is a feature - yet it comes w/a downside:
As a long time Biz Owner/Engineer w/in the Display field - I'd vote for UNIVERSAL over "Pre-Designed Package" ALWAYS! (in the event user's "Strike Gold" w/their application - User creation of "their OWN" such Display Package will, "Save a Fortune" and BEST ACCOMMODATE their precise needs!
Would it not prove "more efficient AND lower cost" to go to the (real) supplier of that 2x20. Middle men/firms extract a price - do they not?
You appear to have (started) to defend the "booster-pack" concept - yet then shift (abruptly/alternately to, "connecting a display" - which highlights the GREAT LIMITATION (and far higher cost) of any "pre-packaged" (solution.) Not to mention the EXTRA (really the BOOSTED) "time & effort" to "FREE the Display" from its "SO Restricted" CONNECTION packaging!
cb1 said:Would it not prove "more efficient AND lower cost" to go to the (real) supplier of that 2x20.
Indeed would. As mentioned, it was a quick major-US-distributor search for a 2x20 LCD, and that p/n is what came up as a reasonable choice. Particularly LCD displays is one item that I don't think we ever sourced from Digi, as they tend to be much less costly going direct to the manufacturer's local rep.
But it is an interesting situation: when you (recently, if I still qualify as such) hopped to a different country and need a few pieces, spending more money at major web seller costs less than figuring out who to talk to locally - you cant do that for EVERY family of component needed!
