Part Number: LAUNCHXL2-TMS57012
Other Parts Discussed in Thread: HALCOGEN
We are using Chip Select -5 of Normal SPI3 of TMS570LS1224PGE (Launch pad board) controller for SPI communication .To configure Chip select-5 of SPI-3 we have used following configuration in SPI Transmit Data Register 1 register :
CS_HOLD = 0;
WDEL = 1;
DFSEL =0; Data word Format 0
CSNR = 0xDF; // 5 bit is low for CS-5
We have checked signal level using Oscilloscope for MOSI, CLK and CS-5 to ensure SPI data is proper. The Chip select-5 remains high always.
We tried with different Chip select configuration by changing CSNR value and measure signal level,
Observed that CS-0, CS-1 and CS-3 are working fine i.e. goes low while transmitting data.
Query:
- Please let us know either our configuration for CS-5 is correct or not ?
- Please let us know if anything needs to be taken care for Chip Select-5 .
Looking forward to hear from you as early as possible.
Thanks in advance.
