Part Number: TMDX570LC43HDK
Other Parts Discussed in Thread: HALCOGEN, DP83640
Hi everybody!
I recently got an evaluation board for the TMS570LC43X processor and I've been trying to build the lwIP demo that is here.
What I did was:
- import the project on CCS using Project/Import project and then looked for
C:\ti\Hercules\HALCoGen EMAC Driver with lwIP Demonstration\v00.03.00\TMS570LC43x\Build-TMS570LC43x
- then, after hitting the Debug button, the compilation starts but it gets stuck when it reaches this message:
'Building target: Build-TMS570LC43x.out'
'Invoking: ARM Linker'
"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.9.0.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi -g --define=_TMS570LC43x_ --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed -z -m"Build-TMS570LC43x.map" --heap_size=0x800 --stack_size=0x800 -i"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.9.0.LTS/lib" -i"C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.9.0.LTS/include" --reread_libs --warn_sections --display_error_number --diag_wrap=off --xml_link_info="Build-TMS570LC43x_linkInfo.xml" --rom_model --be32 -o "Build-TMS570LC43x.out" "./HALCoGen-TMS570LC43x/source/HL_emac.obj" "./HALCoGen-TMS570LC43x/source/HL_epc.obj" "./HALCoGen-TMS570LC43x/source/HL_errata.obj" "./HALCoGen-TMS570LC43x/source/HL_esm.obj" "./HALCoGen-TMS570LC43x/source/HL_mdio.obj" "./HALCoGen-TMS570LC43x/source/HL_nmpu.obj" "./HALCoGen-TMS570LC43x/source/HL_notification.obj" "./HALCoGen-TMS570LC43x/source/HL_phy_dp83640.obj" "./HALCoGen-TMS570LC43x/source/HL_pinmux.obj" "./HALCoGen-TMS570LC43x/source/HL_sci.obj" "./HALCoGen-TMS570LC43x/source/HL_sys_core.obj" "./HALCoGen-TMS570LC43x/source/HL_sys_dma.obj" "./HALCoGen-TMS570LC43x/source/HL_sys_intvecs.obj" "./HALCoGen-TMS570LC43x/source/HL_sys_main.obj" "./HALCoGen-TMS570LC43x/source/HL_sys_mpu.obj" "./HALCoGen-TMS570LC43x/source/HL_sys_pcr.obj" "./HALCoGen-TMS570LC43x/source/HL_sys_phantom.obj" "./HALCoGen-TMS570LC43x/source/HL_sys_pmm.obj" "./HALCoGen-TMS570LC43x/source/HL_sys_pmu.obj" "./HALCoGen-TMS570LC43x/source/HL_sys_selftest.obj" "./HALCoGen-TMS570LC43x/source/HL_sys_startup.obj" "./HALCoGen-TMS570LC43x/source/HL_sys_vim.obj" "./HALCoGen-TMS570LC43x/source/HL_system.obj" "./example/hdk/src/lwip_main.obj" "./lwip-1.4.1/apps/httpserver_raw/fs.obj" "./lwip-1.4.1/apps/httpserver_raw/httpd.obj" "./lwip-1.4.1/ports/hdk/lwiplib.obj" "./lwip-1.4.1/src/core/def.obj" "./lwip-1.4.1/src/core/timers.obj" "./lwip-1.4.1/src/netif/ethernetif.obj" "C:/ti/Hercules/HALCoGen EMAC Driver with lwIP Demonstration/v00.03.00/TMS570LC43x/HALCoGen-TMS570LC43x/source/HL_sys_link.cmd" -lrtsv7R4_T_be_v3D16_eabi.lib
<Linking>
I understand it has to do with the linker... Any thoughts?
My setup:
- Windows 10 x64
- CCS Version: 7.0.0.00043
Thank you!!
