Just a quick question: Will I run into any problems changing the pwm pins in the EK_TM4C123GXL.c file? I need these pins for a capture/compare. Thank you.
* ======== EK_TM4C123GXL_initPWM ========
void EK_TM4C123GXL_initPWM(void)
/* Enable PWM peripherals */
SysCtlPeripheralEnable(SYSCTL_PERIPH_PWM1);
* Enable PWM output on GPIO pins. Board_LED1 and Board_LED2 are now
* controlled by PWM peripheral - Do not use GPIO APIs.
GPIOPinConfigure(GPIO_PF2_M1PWM6);
GPIOPinConfigure(GPIO_PF3_M1PWM7);
GPIOPinTypePWM(GPIO_PORTF_BASE, GPIO_PIN_2 |GPIO_PIN_3);
PWM_init();
