Part Number: TM4C129DNCPDT
Hi Champs,
Customer would like to know will SYSCTL#23 trigger faultISR. Because they face the problem which they use software reset function+ tivaware 2.1.0.
After running code one hour, code will be trapped in faultISR. They check errata and found SYSCTL#23 will cause bus fault on reset. They change software to tivaware 2.1.4 and reset won't be triggered. They want to know is SYSCTL#23 really the root cause. Therefore, they want to know does bus fault will trigger faultISR?
Thanks for your reply in advance.
