Part Number: TM4C1230C3PM
Hi All,
In recent EMI test we found a high EMI at about 127MHz. The detailed information like below picture:
what's the reason about this phenomenon and how to resolve this problem.
thank you so much.
Hi All,
thank you so much.
i'm sorry and i have already post the picture again. please see the problem again. thank you.
Charles Tsai said:and if you use your custom board for the EMC test.
Board layout along w/power distribution/routing - so often prove critical in such "EMI" evaluations. Minus such data - nothing of consequence is likely to emerge from such request. (Vendor's Charles may determine the likelihood of "custom" by noting if user's "4C1230C3 MCU" appears upon (any) factory eval board.)
Yet - would not vendor published, "typical EMI test results" - across a variety of vendor produced boards - offer great insight & value? (i.e. (some) knowledge beats NO knowledge!)
It (would) be highly useful - both to requesting poster (& his client) - along w/so many here - if such EMI measurements could be performed upon (each) of the factory produced boards! Such would - at minimum - provide a (greatly valuable/comforting) "EMI Baseline" - which would serve to, "Speed, Ease, Enhance" the comparison of "Custom boards" to "Factory Standards!"
In addition - the identification of such recommended EMI Test Conditions/Configurations - measurement equipment and/or standards - would lead to greater "uniformity" of such tests.
Minus such "EMI standard" - are not ALL client-users - simply, "Shooting in the Dark?" (and - is that the best - for all here?)
Ideally - a "proper" EMI focused software routine - engaging individual MCU peripherals - and allowing different System Clock frequencies (thus providing great insight into the "potency" of different EMI generators) - would serve to yield a "reasonable" (apple to apple) EMI comparison...
Might it be true that many/most such "Eval boards" emphasize "low cost" - and as such - EMI concerns/management were not "optimized?" Even if true - especially if true - (some) Baseline trumps NO Baseline!
