TM4C1290NCPDT: Which SRAM and SDRAM we use with TM4C1290NCPDT using EPI
Part Number: TM4C1290NCPDT
I want to use SRAM or SDRAM in one of my project with TM4C1290NCPDT microcontroller using EPI. Did anyone use them, if yes then please suggest the part number and the procedure to configure it in our project.
  • I will let others suggest part numbers, but I suggest you review section 11 of the TivaWare Peripheral Driver Library for the functions to configure the EPI.
    For this to serve as (really) "YOUR" project - should you not be FAR MORE (i.e. somewhat) involved in the: "Search, Selection and Configuration" of an appropriate memory device?
    Minus that focused effort - by you - how can "someone's past provided project" (properly & factually) be considered, "YOUR" project?
    Is not that time & effort investment in the discovery of a "suitable memory device" - very much a key/critical part - of  "YOUR" project?
  • Thanks for reply actually i want the part number of SRAM and SDRAM which can work together with TM4C1290 and hardware design also
  • Again - vendor has guided you to the MCU's data.
    After your (serious) read/review - don't "you" benefit from investigating the selection criteria for "SRAM and SDRAM?"
    That investigation - and resultant learning/understanding - should be an important "part" of  "your" project" - should they not?
