Other Parts Discussed in Thread: TM4C123AH6PM, EK-TM4C129EXL
Two suggestions to improve PinMux tool (Cloud):
(1) Once you choose a specific MCU, nowhere in the PinMux tool does it show the MCU part number, nor does it appear in the generated code. This should be displayed in both!
(2) If you run up against the limits of a specific MCU, it would be great if you could switch to a different MCU without having to re-enter all your work from scratch.
This will help greatly in the use case where the designer does not know ahead of time which specific MCU variant to specify for a board design and needs to experiment with different ones until an optimal one is found.
