Part Number: TM4C1294NCPDT
Other Parts Discussed in Thread: EK-TM4C1294XL,
Hello
I working in a LWIP server and I use the FreeRTOS and Tivaware 2.1.3.156 in this project.
I create an html page to display some values via ssi tags. This page is automatically refreshed every 1 second, via meta tag in html:
<meta http-equiv="refresh" content="2" />
After a few seconds, the server stops working. But when a remove the automatically refresh, the issue ocurrs in a few hours.
I try to make it in the enet_io example, but the same issue ocurrs.
This is the my lwipops.h file:
// lwipopts.h - Configuration file for lwIP
// Copyright (c) 2013-2016 Texas Instruments Incorporated. All rights reserved.
// Software License Agreement
// Texas Instruments (TI) is supplying this software for use solely and
// exclusively on TI's microcontroller products. The software is owned by
// TI and/or its suppliers, and is protected under applicable copyright
// laws. You may not combine this software with "viral" open-source
// software in order to form a larger program.
// THIS SOFTWARE IS PROVIDED "AS IS" AND WITH ALL FAULTS.
// NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT
// NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. TI SHALL NOT, UNDER ANY
// CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR CONSEQUENTIAL
// DAMAGES, FOR ANY REASON WHATSOEVER.
// This is part of revision 2.1.3.156 of the EK-TM4C1294XL Firmware Package.
// NOTE: This file has been derived from the lwIP/src/include/lwip/opt.h
// header file.
// For additional details, refer to the original "opt.h" file, and lwIP
// documentation.
#ifndef __LWIPOPTS_H__
#define __LWIPOPTS_H__
#include <stdint.h>
// ---------- Stellaris / lwIP Port Options ----------
#define HOST_TMR_INTERVAL 10 // default is 0
//#define DHCP_EXPIRE_TIMER_MSECS (60 * 1000)
#define LWIP_HTTPD_SSI 1
#define LWIP_HTTPD_CGI 1
#define LWIP_HTTPD_DYNAMIC_HEADERS 1
//#define EMAC_PHY_CONFIG EMAC_PHY_TYPE_EXTERNAL_RMII
//#define PHY_PHYS_ADDR 1
#define EMAC_PHY_CONFIG (EMAC_PHY_TYPE_INTERNAL | EMAC_PHY_INT_MDIX_EN | \
EMAC_PHY_AN_100B_T_FULL_DUPLEX)
#define PHY_PHYS_ADDR 0
#define NUM_TX_DESCRIPTORS 8
#define NUM_RX_DESCRIPTORS 8
// ---------- Platform specific locking ----------
#define SYS_LIGHTWEIGHT_PROT 1 // default is 0
#define NO_SYS 0 // default is 0
#if !NO_SYS
#define LWIP_COMPAT_MUTEX 1
#define RTOS_FREERTOS 1
#endif /* !NO_SYS */
//#define MEMCPY(dst,src,len) memcpy(dst,src,len)
//#define SMEMCPY(dst,src,len) memcpy(dst,src,len)
// ---------- Memory options ----------
//#define MEM_LIBC_MALLOC 0
#define MEM_ALIGNMENT 4
#define MEM_SIZE (64 * 1024)
//#define MEMP_OVERFLOW_CHECK 0
//#define MEMP_SANITY_CHECK 0
//#define MEM_USE_POOLS 0
//#define MEMP_USE_CUSTOM_POOLS 0
// ---------- Internal Memory Pool Sizes ----------
#define MEMP_NUM_PBUF 16 // Default 16, was 16
//#define MEMP_NUM_RAW_PCB 4
//#define MEMP_NUM_UDP_PCB 4
#define MEMP_NUM_TCP_PCB 40
//#define MEMP_NUM_TCP_PCB_LISTEN 8
//#define MEMP_NUM_TCP_SEG 16
//#define MEMP_NUM_REASSDATA 5
//#define MEMP_NUM_ARP_QUEUE 30
//#define MEMP_NUM_IGMP_GROUP 8
#define MEMP_NUM_SYS_TIMEOUT 10 //5
//#define MEMP_NUM_NETBUF 2
//#define MEMP_NUM_NETCONN 4
//#define MEMP_NUM_TCPIP_MSG_API 8
//#define MEMP_NUM_TCPIP_MSG_INPKT 8
#define PBUF_POOL_SIZE 64 // Default 16
// ---------- ARP options ----------
//#define LWIP_ARP 1
//#define ARP_TABLE_SIZE 10
//#define ARP_QUEUEING 1
//#define ETHARP_TRUST_IP_MAC 1
// ---------- IP options ----------
//#define IP_FORWARD 0
//#define IP_OPTIONS_ALLOWED 1
#define IP_REASSEMBLY 0 // default is 1
#define IP_FRAG 0 // default is 1
//#define IP_REASS_MAXAGE 3
//#define IP_REASS_MAX_PBUFS 10
//#define IP_FRAG_USES_STATIC_BUF 1
//#define IP_FRAG_MAX_MTU 1500
//#define IP_DEFAULT_TTL 255
// ---------- ICMP options ----------
//#define LWIP_ICMP 1
//#define ICMP_TTL (IP_DEFAULT_TTL)
// ---------- RAW options ----------
//#define LWIP_RAW 1
//#define RAW_TTL (IP_DEFAULT_TTL)
// ---------- DHCP options ----------
#define LWIP_DHCP 1 // default is 0
//#define DHCP_DOES_ARP_CHECK ((LWIP_DHCP) && (LWIP_ARP))
// ---------- UPNP options ----------
//#define LWIP_UPNP 0
// ---------- PTPD options ----------
//#define LWIP_PTPD 0
// ---------- AUTOIP options ----------
#define LWIP_AUTOIP 1 // default is 0
#define LWIP_DHCP_AUTOIP_COOP ((LWIP_DHCP) && (LWIP_AUTOIP))
// default is 0
#define LWIP_DHCP_AUTOIP_COOP_TRIES 5 // default is 9
// ---------- SNMP options ----------
#define LWIP_SNMP 1 // 0
#define SNMP_CONCURRENT_REQUESTS 1
#define SNMP_TRAP_DESTINATIONS 1
#define SNMP_PRIVATE_MIB 0
#define SNMP_SAFE_REQUESTS 1
// ---------- IGMP options ----------
//#define LWIP_IGMP 0
// ---------- DNS options -----------
#define LWIP_DNS 0
#define DNS_TABLE_SIZE 4
#define DNS_MAX_NAME_LENGTH 256
#define DNS_MAX_SERVERS 2
#define DNS_DOES_NAME_CHECK 1
#define DNS_USES_STATIC_BUF 1
#define DNS_MSG_SIZE 512
// ---------- UDP options ----------
#define LWIP_UDP 1
//#define LWIP_UDPLITE 0
//#define UDP_TTL (IP_DEFAULT_TTL)
// ---------- TCP options ----------
#define LWIP_TCP 1
//#define TCP_TTL (IP_DEFAULT_TTL)
#define TCP_WND 4096 // default is 2048
//#define TCP_MAXRTX 12
//#define TCP_SYNMAXRTX 6
//#define TCP_QUEUE_OOSEQ 1
#define TCP_MSS 1500 // default is 128
//#define TCP_CALCULATE_EFF_SEND_MSS 1
#define TCP_SND_BUF (4 * TCP_MSS)
// default is 256, was 6 *
//#define TCP_SND_QUEUELEN (4 * (TCP_SND_BUF/TCP_MSS))
//#define TCP_SNDLOWAT (TCP_SND_BUF/2)
//#define TCP_LISTEN_BACKLOG 0
//#define TCP_DEFAULT_LISTEN_BACKLOG 0xff
// ---------- API options ----------
//#define LWIP_EVENT_API 0
//#define LWIP_CALLBACK_API 1
// ---------- Pbuf options ----------
#define PBUF_LINK_HLEN 16 // default is 14
#define PBUF_POOL_BUFSIZE 512
// default is LWIP_MEM_ALIGN_SIZE(TCP_MSS+40+PBUF_LINK_HLEN)
#define ETH_PAD_SIZE 0 // default is 0
// ---------- Network Interfaces options ----------
//#define LWIP_NETIF_HOSTNAME 0
//#define LWIP_NETIF_API 0
//#define LWIP_NETIF_STATUS_CALLBACK 0
//#define LWIP_NETIF_LINK_CALLBACK 0
//#define LWIP_NETIF_HWADDRHINT 0
// ---------- LOOPIF options ----------
//#define LWIP_HAVE_LOOPIF 0
//#define LWIP_LOOPIF_MULTITHREADING 1
// ---------- Thread options ----------
#define TCPIP_THREAD_NAME "tcpip"
#define TCPIP_THREAD_STACKSIZE 2048
#define TCPIP_THREAD_PRIO 14
#define TCPIP_MBOX_SIZE 32
//#define SLIPIF_THREAD_NAME "slipif_loop"
//#define SLIPIF_THREAD_STACKSIZE 0
//#define SLIPIF_THREAD_PRIO 1
//#define PPP_THREAD_NAME "pppMain"
//#define PPP_THREAD_STACKSIZE 0
//#define PPP_THREAD_PRIO 1
//#define DEFAULT_THREAD_NAME "lwIP"
//#define DEFAULT_THREAD_STACKSIZE 0
//#define DEFAULT_THREAD_PRIO 1
//#define DEFAULT_RAW_RECVMBOX_SIZE 0
//#define DEFAULT_UDP_RECVMBOX_SIZE 0
//#define DEFAULT_TCP_RECVMBOX_SIZE 0
//#define DEFAULT_ACCEPTMBOX_SIZE 0
// ---------- Sequential layer options ----------
//#define LWIP_TCPIP_CORE_LOCKING 0
#define LWIP_NETCONN 0 // default is 1
// ---------- Socket Options ----------
#define LWIP_SOCKET 0 // default is 1
//#define LWIP_COMPAT_SOCKETS 1
//#define LWIP_POSIX_SOCKETS_IO_NAMES 1
//#define LWIP_TCP_KEEPALIVE 0
//#define LWIP_SO_RCVTIMEO 0
//#define LWIP_SO_RCVBUF 0
//#define SO_REUSE 0
// ---------- Statistics options ----------
//#define LWIP_STATS 1
//#define LWIP_STATS_DISPLAY 1//0
//#define LINK_STATS 1
//#define ETHARP_STATS (LWIP_ARP)
//#define IP_STATS 1
//#define IPFRAG_STATS (IP_REASSEMBLY || IP_FRAG)
//#define ICMP_STATS 1
//#define IGMP_STATS (LWIP_IGMP)
//#define UDP_STATS (LWIP_UDP)
//#define TCP_STATS (LWIP_TCP)
//#define MEM_STATS 1
//#define MEMP_STATS 1
//#define SYS_STATS 1
// ---------- PPP options ----------
//#define PPP_SUPPORT 0
//#define PPPOE_SUPPORT 0
//#define PPPOS_SUPPORT PPP_SUPPORT
#if PPP_SUPPORT
//#define NUM_PPP 1
//#define PAP_SUPPORT 0
//#define CHAP_SUPPORT 0
//#define MSCHAP_SUPPORT 0
//#define CBCP_SUPPORT 0
//#define CCP_SUPPORT 0
//#define VJ_SUPPORT 0
//#define MD5_SUPPORT 0
//#define FSM_DEFTIMEOUT 6
//#define FSM_DEFMAXTERMREQS 2
//#define FSM_DEFMAXCONFREQS 10
//#define FSM_DEFMAXNAKLOOPS 5
//#define UPAP_DEFTIMEOUT 6
//#define UPAP_DEFREQTIME 30
//#define CHAP_DEFTIMEOUT 6
//#define CHAP_DEFTRANSMITS 10
//#define LCP_ECHOINTERVAL 0
//#define LCP_MAXECHOFAILS 3
//#define PPP_MAXIDLEFLAG 100
//#define PPP_MAXMTU 1500
//#define PPP_DEFMRU 296
#endif
// ---------- checksum options ----------
#define CHECKSUM_GEN_IP 0
#define CHECKSUM_GEN_ICMP 0
#define CHECKSUM_GEN_UDP 0
#define CHECKSUM_GEN_TCP 0
#define CHECKSUM_CHECK_IP 0
#define CHECKSUM_CHECK_UDP 0
#define CHECKSUM_CHECK_TCP 0
// ---------- Debugging options ----------
#if 1//def DEBUG
#define U8_F "c"
#define S8_F "c"
#define X8_F "02x"
#define U16_F "u"
#define S16_F "d"
#define X16_F "x"
#define U32_F "u"
#define S32_F "d"
#define X32_F "x"
extern void UARTprintf(const char *pcString, ...);
#define LWIP_PLATFORM_DIAG(msg) UARTprintf msg
#define LWIP_PLATFORM_ASSERT(msg) \
UARTprintf("ASSERT FAIL at line %d of %s: %s\n", __LINE__, __FILE__, msg)
#define LWIP_DEBUG 1
#endif
//#define LWIP_DBG_MIN_LEVEL LWIP_DBG_LEVEL_OFF
//#define LWIP_DBG_MIN_LEVEL LWIP_DBG_LEVEL_WARNING
#define LWIP_DBG_MIN_LEVEL LWIP_DBG_LEVEL_SERIOUS
//#define LWIP_DBG_MIN_LEVEL LWIP_DBG_LEVEL_SEVERE
//#define LWIP_DBG_TYPES_ON LWIP_DBG_ON
//#define LWIP_DBG_TYPES_ON (LWIP_DBG_ON|LWIP_DBG_TRACE| \
LWIP_DBG_STATE|LWIP_DBG_FRESH)
//#define ETHARP_DEBUG LWIP_DBG_ON // default is OFF
#define NETIF_DEBUG LWIP_DBG_OFF
//#define PBUF_DEBUG LWIP_DBG_OFF
//#define API_LIB_DEBUG LWIP_DBG_OFF
//#define API_MSG_DEBUG LWIP_DBG_OFF
//#define SOCKETS_DEBUG LWIP_DBG_OFF
#define HTTPD_DEBUG LWIP_DBG_OFF
//#define ICMP_DEBUG LWIP_DBG_OFF
//#define IGMP_DEBUG LWIP_DBG_OFF
//#define INET_DEBUG LWIP_DBG_OFF
//#define IP_DEBUG LWIP_DBG_ON
//#define IP_REASS_DEBUG LWIP_DBG_OFF
#define RAW_DEBUG LWIP_DBG_OFF
#define MEM_DEBUG LWIP_DBG_ON
//#define MEMP_DEBUG LWIP_DBG_OFF
//#define SYS_DEBUG LWIP_DBG_OFF
//#define TCP_DEBUG LWIP_DBG_ON
#define TCP_INPUT_DEBUG LWIP_DBG_ON
//#define TCP_FR_DEBUG LWIP_DBG_OFF
//#define TCP_RTO_DEBUG LWIP_DBG_OFF
//#define TCP_CWND_DEBUG LWIP_DBG_OFF
//#define TCP_WND_DEBUG LWIP_DBG_OFF
#define TCP_OUTPUT_DEBUG LWIP_DBG_ON
//#define TCP_RST_DEBUG LWIP_DBG_OFF
//#define TCP_QLEN_DEBUG LWIP_DBG_OFF
//#define UDP_DEBUG LWIP_DBG_ON // default is OFF
//#define TCPIP_DEBUG LWIP_DBG_ON
//#define PPP_DEBUG LWIP_DBG_OFF
//#define SLIP_DEBUG LWIP_DBG_OFF
//#define DHCP_DEBUG LWIP_DBG_ON // default is OFF
//#define AUTOIP_DEBUG LWIP_DBG_OFF
//#define SNMP_MSG_DEBUG LWIP_DBG_OFF
//#define SNMP_MIB_DEBUG LWIP_DBG_OFF
//#define DNS_DEBUG LWIP_DBG_OFF
// Error Defines
#define LWIP_PROVIDE_ERRNO 1
#define LWIP_COMPAT_MUTEX_ALLOWED 1
// Ethernet Interface Functionality Enable Defines
#define HTTP_ENABLE_PASSWORD 1
#define HTTP_ENABLE_SESSION_TIMEOUT 1
#endif /* __LWIPOPTS_H__ */
How I could fixed this problem?
