In the TMS570LC4357 memory map in the TRM, the area before the RAM is indicated as "Reserved" (from 0x0040_0000 to 0x07FF_FFFF).
As the behaviour to this reserved section is not described neither in the TRM nor the Datasheet documents, what is the CPU Interconnect behaviour if the core tries to read or write to this area? Will it generate an abort to the core to get an Abort exception, or will the access only be ignored?
Thanks for the clarification,
Best regards
Gael
