Hello ,
I have a problem that the tm4c123gh6pm is not recognized on my laptop , I tried another laptop but the same problem
any suggestion
regards ,
Hello ,
any suggestion
regards ,
My friend - while "feeling your pain" - many more facts are needed to correct your issue. A few follow:
There is an excellent "Search Facility" (top line of this forum) which reveals (many) w/your issue.
In addition - the (very) top "sticky post" has specific mention & recommendations to overcome your issue.
At times the USB cable - connecting PC to the MCU board - has proved suspect. Switching to one "known good" removes that doubt.
Lack of MCU recognition (alone) is not that common - hopefully these suggestions will speed & ease your 'find" & correction...
muhammad moutiry said:I tried another kit and it is working
Good that - firm/I are huge advocates of, "Employing more than one (new) device - especially for "first time use."
As you've got one kit (assumed to be LPad) working - your download & install of required PC files appears correct.
Is it true that you (earlier) attempted to program that "not recognized" board - and only then did it assume, "Non recognized status?" (all those boards are tested prior to packing/shipment)
