Part Number: TM4C123GH6PM
How can I program the tm4c123gh6pm using UART
Earlier you wrote of, "Failed MCU Recognition." Has that issue (now) been solved? (hope so)
(I had just "recognized" & responded to (that) post...)
May I note that should you be "beginning" w/this device - JTAG Programming is vastly easier! And if yours is a LaunchPad - you may program your board (directly) via the PC to MCU's USB connection.
Other programming methods ARE possible - yet often prove too difficult for those (early) in the learning process...
Indeed - yet "Step One" requires the PC to recognize the MCU. An earlier (flawed) program is the cause of most all such, "Failed recognitions."
