Compiler: Which Controller support to Send my Sensor data on AWS IOT using GSM/GPRS Module only?
I am Searching controller for sending my data to AWS IoT but until not find spefic controller for my application. So can anyone know such controller also how to use GSM/GPRS module for AWS IoT please let me know.
Thanks in Advanced...........
  • If you are looking for a microcontroller that can interface to a GSM/GPRS module, most with a UART can do that. If you are looking for a software example that connects to a GSM/GPRS module and sends information to AWS, I don't have one.
  • Thanks sir for giving me your reply, can you suggest me what should i do for my project.
    Thanks and Regards,
    Vishal
  • Vishal B said:
    ...can you suggest ... what should I do for my project.
    Might there be more fundamental questions - not (yet) appearing - w/in your request?        How did you choose such a project?        Would it not prove better to select a project which is better "known & supported" (i.e. "somewhat" known/supported) by the MCUs found here?
    Part of such Project "choice/selection" demands your expanded skills/effort as a Tech,  "Investigator."      Has your instructor, boss, or (other) "driver of this project" properly guided you in this "most necessary" investigative requirement?       Landing here - with so broad a request (and minus any evidence of your investment of properly focused, time/effort) is NOT your best pathway towards project success!
    In direct answer to, "What should I do..."
    • choose a project which falls w/in the "known" capabilities of this forum's MCUs  ... OR
    • cast a wider, investigative net, focused upon your (keywords): "AWS IOT & GSM/GPRS"
    • report the, "Lack of a key support requirement" found here, to the "project's driver."    They must be (quickly) advised of your findings.
    In both cases - you must devise a method which efficiently reveals the capabilities of MANY MCUs - perhaps even those "outside" these red hallways...     BTW - improving your "investigative techniques/methods/effort" is likely to prove beneficial to many (other - non-Tech) aspects of your life - thus warrants your serious consideration...
