Part Number: TM4C1231H6PM
Hello everybody,
i've made my own card with a TM4C1231H6PM MCU, and after soldering all component ,
i would like to know how implement my code ?
Hello everybody,
Hi Charles,
the software is ok, i've already make my program tested and it's work on the tm4c123gxl eval kit .
after that i've made my own card with the MCU and some component .
Now i would like to know how put my code on the MCU without the JTAG .
yacine ould said:Now i would like to know how put my code on the MCU without the JTAG .
Might that (specific) question have (better) appeared w/in your FIRST post? (impossible for Vendor's Charles to know (that) was your real (yet well HIDDEN) desire!)
Your "rejection" of JTAG can be expected to place "Added & Great demands" upon you. (and "helpers" here) You should - at minimum - have that awareness...
Isn't it also possible to use the ROM boot loader, without having to program anything via JTAG?Charles Tsai said:Note that the bootloader still needs to be programmed via the JTAG interface.
May it be noted that, "Provisioning for a JTAG Header, pull-up & protective series resistors, & JTAG trace routings" serve as a most excellent, "Insurance Policy" - both during development and long into the future.
At times - Only "Rescue via JTAG/SWD" - proves the safest, easiest & most direct course...
Robert Adsett72 said:Actually, I'd view using the bootloader as your first/ primary programming method a bit quixotic.
Just a "bit?" Your earlier mention of, "Rejecting JTAG" (i.e. FOOLHARDY) bubbles up (very) quickly/forcefully!
As ALWAYS - posters fail to present (doubtful they even "consider") (any) justification for, "Inviting Complications" which are almost guaranteed to seriously delay (even jeopardize) their projects.
Encouraging such, "too early, door-opening to complexity" is unlikely to best serve any vendor... Some "new-user CAUTION" (Attention to Detail required) would appear warranted - would it not?
