Part Number: TM4C129ENCPDT
Hi
I do not know why while using this code the program gets stuck in the IntDefaultHandler(void) in the start up file, i know that is because an unexpected interruption was called, what I want to know is what is wrong with this code:
void ADCconfigure(uint32_t sysclock)
SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC0);
SysCtlPeripheralSleepEnable(SYSCTL_PERIPH_ADC0);
ADCClockConfigSet(ADC0_BASE,ADC_CLOCK_SRC_PIOSC | ADC_CLOCK_RATE_FULL, 1); //Clock source (Precision Internal Clock)
ADCSequenceConfigure(ADC0_BASE, 1, ADC_TRIGGER_TIMER, 0); // SS0-SS3 priorities must always be different
ADCSequenceStepConfigure(ADC0_BASE, 1, 0, ADC_CTL_CH0);
ADCSequenceStepConfigure(ADC0_BASE, 1, 1, ADC_CTL_CH1);
ADCSequenceStepConfigure(ADC0_BASE, 1, 2, ADC_CTL_CH2);
ADCSequenceStepConfigure(ADC0_BASE, 1, 3, ADC_CTL_CH3 | ADC_CTL_END | ADC_CTL_IE);
ADCSequenceDMAEnable(ADC0_BASE, 1);
uDMAChannelAttributeDisable(UDMA_CHANNEL_ADC1,
UDMA_ATTR_ALTSELECT | UDMA_ATTR_USEBURST |
UDMA_ATTR_HIGH_PRIORITY |
UDMA_ATTR_REQMASK);
uDMAChannelControlSet(UDMA_CHANNEL_ADC1 | UDMA_PRI_SELECT,
UDMA_SIZE_16 | UDMA_SRC_INC_NONE | UDMA_DST_INC_16 |
UDMA_ARB_1);
uDMAChannelControlSet(UDMA_CHANNEL_ADC1 | UDMA_ALT_SELECT,
UDMA_ARB_1);
uDMAChannelTransferSet(UDMA_CHANNEL_ADC1 | UDMA_PRI_SELECT,
UDMA_MODE_PINGPONG,
(void *)(ADC0_BASE + ADC_O_SSFIFO1),
g_ui8RxBufA[0], MEM_BUFFER_SIZE);
uDMAChannelTransferSet(UDMA_CHANNEL_ADC1 | UDMA_ALT_SELECT,
UDMA_MODE_PINGPONG,
g_ui8RxBufB[0], MEM_BUFFER_SIZE);
uDMAChannelEnable(UDMA_CHANNEL_ADC1);
ADCIntEnableEx(ADC0_BASE, ADC_INT_DMA_SS1);
IntEnable(INT_ADC0SS1);
SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC1);
SysCtlPeripheralSleepEnable(SYSCTL_PERIPH_ADC1);
ADCClockConfigSet(ADC1_BASE,ADC_CLOCK_SRC_PIOSC | ADC_CLOCK_RATE_FULL, 1);
ADCSequenceConfigure(ADC1_BASE, 1, ADC_TRIGGER_TIMER, 1);
ADCSequenceStepConfigure(ADC1_BASE, 1, 0, ADC_CTL_CH16);
ADCSequenceStepConfigure(ADC1_BASE, 1, 1, ADC_CTL_CH17);
ADCSequenceStepConfigure(ADC1_BASE, 1, 2, ADC_CTL_CH18);
ADCSequenceStepConfigure(ADC1_BASE, 1, 3, ADC_CTL_CH19 | ADC_CTL_END | ADC_CTL_IE); // ADC_CTL_IE fires every 8 samples
ADCPhaseDelaySet(ADC1_BASE, ADC_PHASE_0);
ADCSequenceDMAEnable(ADC1_BASE, 1);
uDMAChannelAttributeDisable(UDMA_CH25_ADC1_1,
UDMA_ATTR_REQMASK);
uDMAChannelControlSet(UDMA_CH25_ADC1_1 | UDMA_PRI_SELECT,
UDMA_ARB_8);
uDMAChannelControlSet(UDMA_CH25_ADC1_1 | UDMA_ALT_SELECT,
UDMA_ARB_8);
uDMAChannelTransferSet(UDMA_CH25_ADC1_1 | UDMA_PRI_SELECT,
UDMA_MODE_PINGPONG,
(void *)(ADC1_BASE + ADC_O_SSFIFO1),
g_ui8RxBufA[1], MEM_BUFFER_SIZE);
uDMAChannelTransferSet(UDMA_CH25_ADC1_1 | UDMA_ALT_SELECT,
UDMA_MODE_PINGPONG,
g_ui8RxBufB[1], MEM_BUFFER_SIZE);
uDMAChannelAssign(UDMA_CH25_ADC1_1);
uDMAChannelEnable(UDMA_CH25_ADC1_1);
ADCIntEnableEx(ADC1_BASE, ADC_INT_DMA_SS1);
IntEnable(INT_ADC1SS1);
SysCtlPeripheralEnable(SYSCTL_PERIPH_TIMER0);
TimerConfigure(TIMER0_BASE, TIMER_CFG_A_PERIODIC);
TimerLoadSet(TIMER0_BASE, TIMER_A, sysclock/(125000)/*(48000*8*2)*/);
TimerControlTrigger(TIMER0_BASE, TIMER_A, true);
TimerEnable(TIMER0_BASE, TIMER_A);
ADCSequenceEnable(ADC0_BASE, 1);
ADCSequenceEnable(ADC1_BASE, 1);
After using the IntEnable(INT_ADC0SS1); the problem appears, I was using before this code, that use Seq 0 and everything works well:
ADCSequenceConfigure(ADC0_BASE, 0, ADC_TRIGGER_TIMER, 0); // SS0-SS3 priorities must always be different
ADCSequenceStepConfigure(ADC0_BASE, 0, 0, ADC_CTL_CH0); // PE3
ADCSequenceStepConfigure(ADC0_BASE, 0, 1, ADC_CTL_CH1); // PE2
ADCSequenceStepConfigure(ADC0_BASE, 0, 2, ADC_CTL_CH2); // PE1
ADCSequenceStepConfigure(ADC0_BASE, 0, 3, ADC_CTL_CH3); // PE0
ADCSequenceStepConfigure(ADC0_BASE, 0, 4, ADC_CTL_CH0);
ADCSequenceStepConfigure(ADC0_BASE, 0, 5, ADC_CTL_CH1);
ADCSequenceStepConfigure(ADC0_BASE, 0, 6, ADC_CTL_CH2);
ADCSequenceStepConfigure(ADC0_BASE, 0, 7, ADC_CTL_CH3 | ADC_CTL_END | ADC_CTL_IE);
ADCSequenceDMAEnable(ADC0_BASE, 0);
uDMAChannelAttributeDisable(UDMA_CHANNEL_ADC0,
UDMA_ATTR_REQMASK);
uDMAChannelControlSet(UDMA_CHANNEL_ADC0 | UDMA_PRI_SELECT,
UDMA_ARB_1);
uDMAChannelControlSet(UDMA_CHANNEL_ADC0 | UDMA_ALT_SELECT,
UDMA_ARB_1);
uDMAChannelTransferSet(UDMA_CHANNEL_ADC0 | UDMA_PRI_SELECT,
UDMA_MODE_PINGPONG,
(void *)(ADC0_BASE + ADC_O_SSFIFO0),
uDMAChannelTransferSet(UDMA_CHANNEL_ADC0 | UDMA_ALT_SELECT,
UDMA_MODE_PINGPONG,
uDMAChannelEnable(UDMA_CHANNEL_ADC0);
ADCIntEnableEx(ADC0_BASE, ADC_INT_DMA_SS0);
IntEnable(INT_ADC0SS0);
ADCSequenceConfigure(ADC1_BASE, 0, ADC_TRIGGER_TIMER, 1);
ADCSequenceStepConfigure(ADC1_BASE, 0, 0, ADC_CTL_CH16); //PK1
ADCSequenceStepConfigure(ADC1_BASE, 0, 1, ADC_CTL_CH17); //PK2
ADCSequenceStepConfigure(ADC1_BASE, 0, 2, ADC_CTL_CH18); //PK3
ADCSequenceStepConfigure(ADC1_BASE, 0, 3, ADC_CTL_CH19); //PK0
ADCSequenceStepConfigure(ADC1_BASE, 0, 4, ADC_CTL_CH16);
ADCSequenceStepConfigure(ADC1_BASE, 0, 5, ADC_CTL_CH17);
ADCSequenceStepConfigure(ADC1_BASE, 0, 6, ADC_CTL_CH18);
ADCSequenceStepConfigure(ADC1_BASE, 0, 7, ADC_CTL_CH19 | ADC_CTL_END | ADC_CTL_IE); // ADC_CTL_IE fires every 8 samples
ADCSequenceDMAEnable(ADC1_BASE, 0);
uDMAChannelAttributeDisable(UDMA_CH24_ADC1_0,
UDMA_ATTR_REQMASK);
uDMAChannelControlSet(UDMA_CH24_ADC1_0 | UDMA_PRI_SELECT,
UDMA_ARB_8);
uDMAChannelControlSet(UDMA_CH24_ADC1_0 | UDMA_ALT_SELECT,
UDMA_ARB_8);
uDMAChannelTransferSet(UDMA_CH24_ADC1_0 | UDMA_PRI_SELECT,
UDMA_MODE_PINGPONG,
(void *)(ADC1_BASE + ADC_O_SSFIFO0),
uDMAChannelTransferSet(UDMA_CH24_ADC1_0 | UDMA_ALT_SELECT,
UDMA_MODE_PINGPONG,
uDMAChannelAssign(UDMA_CH24_ADC1_0);
uDMAChannelEnable(UDMA_CH24_ADC1_0);
ADCIntEnableEx(ADC1_BASE, ADC_INT_DMA_SS0);
IntEnable(INT_ADC1SS0);
ADCSequenceEnable(ADC0_BASE, 0);
ADCSequenceEnable(ADC1_BASE, 0);
What could be wrong with my ADC Seq1 DMA configuration????
