RTOS: OPC UA - ANSI C Stack
Tool/software: TI-RTOS
Last time I started a thread for OPC UA. Now I am planning to restart the project.
As I look around I found to ways to go ahead. One is the purchase license from an SDK Vendor such as Matrikon or implement my own solution. I am waiting for reply from them, because their licensing model is not clear for me.
Right now I like the 2nd option. Do you have any experience with OPC UA ANSI C source?
What do you think about the OPC UA ANSI C - TI RTOS integration? I don't see any issue that makes the integration impossible. Do you?
Thank you for your reply
  • I'm not familiar with OPC UA. Maybe someone else on this forum has some experience and can comment. I think you should review the TI-RTOS docs and examples and come back with more specific concerns or questions.
    -Karl-
  • Hello, well I have a specific question.
    I am trying to port the following code section to TI-RTOS:
    OpcUa_StatusCode OpcUa_P_RawSocket_CreateSocketPair(  OpcUa_RawSocket* pRawSocketRead, OpcUa_RawSocket* pRawSocketWrite)
          int filedes[2];
          int retval = socketpair(AF_UNIX, SOCK_STREAM, 0, filedes);
          if(retval<0)
            *pRawSocketRead  = (OpcUa_RawSocket)OPCUA_P_SOCKET_INVALID;
            *pRawSocketWrite = (OpcUa_RawSocket)OPCUA_P_SOCKET_INVALID;
            return OpcUa_Bad;
          *pRawSocketRead  = (OpcUa_RawSocket)filedes[1];
          *pRawSocketWrite = (OpcUa_RawSocket)filedes[0];
           return OpcUa_Good;
    And my problem is how can I implement socketpair() in RTOS? Any idea?
    Found an example of how to implement socketpair() using socket primitives, albeit in Python rather than C - https://gist.github.com/geertj/4325783
    Does that help?
