Other Parts Discussed in Thread: TM4C123GH6PM
Hi
I am using Tiva C Series TM4C123G LaunchPad Evaluation Board with TM4C123GH6PM Microcontroller.
My IDE is Keil and the debugger doesn't start and the code is stack before executing the main.
My settings:
Flash Load is OK. But as I press on debug button I jump to the Startup.s code instead of main
At this point, the debugger is disabled
When I reset the CPU, the debugger is enabled, but after couple of steps I am still stack in this Startup.s code
Could you please advice where and what I did wrong?
Thank you very much
