Part Number: TM4C123GH6PM
Other Parts Discussed in Thread: EK-TM4C123GXL
I have an issue with CAN Bus connection
TX
#include <stdbool.h>
#include <stdint.h>
#include "inc/hw_can.h"
#include "inc/hw_ints.h"
#include "inc/hw_memmap.h"
#include "inc/hw_types.h"
#include "driverlib/can.h"
#include "driverlib/gpio.h"
#include "driverlib/interrupt.h"
#include "driverlib/pin_map.h"
#include "driverlib/sysctl.h"
#include "driverlib/uart.h"
#include "utils/uartstdio.h"
#include "utils/uartstdio.c"
// simple_tx.c - Example demonstrating simple CAN message transmission.
// Copyright (c) 2010-2017 Texas Instruments Incorporated. All rights reserved.
// Software License Agreement
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
// Redistributions of source code must retain the above copyright
// notice, this list of conditions and the following disclaimer.
// Redistributions in binary form must reproduce the above copyright
// notice, this list of conditions and the following disclaimer in the
// documentation and/or other materials provided with the
// distribution.
// Neither the name of Texas Instruments Incorporated nor the names of
// its contributors may be used to endorse or promote products derived
// from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// This is part of revision 2.1.4.178 of the Tiva Firmware Development Package.
//! \addtogroup can_examples_list
//! <h1>Simple CAN TX (simple_tx)</h1>
//! This example shows the basic setup of CAN in order to transmit messages
//! on the CAN bus. The CAN peripheral is configured to transmit messages
//! with a specific CAN ID. A message is then transmitted once per second,
//! using a simple delay loop for timing. The message that is sent is a 4
//! byte message that contains an incrementing pattern. A CAN interrupt
//! handler is used to confirm message transmission and count the number of
//! messages that have been sent.
//! This example uses the following peripherals and I/O signals. You must
//! review these and change as needed for your own board:
//! - CAN0 peripheral
//! - GPIO Port B peripheral (for CAN0 pins)
//! - CAN0RX - PB4
//! - CAN0TX - PB5
//! The following UART signals are configured only for displaying console
//! messages for this example. These are not required for operation of CAN.
//! - GPIO port A peripheral (for UART0 pins)
//! - UART0RX - PA0
//! - UART0TX - PA1
//! This example uses the following interrupt handlers. To use this example
//! in your own application you must add these interrupt handlers to your
//! vector table.
//! - INT_CAN0 - CANIntHandler
// A counter that keeps track of the number of times the TX interrupt has
// occurred, which should match the number of TX messages that were sent.
volatile uint32_t g_ui32MsgCount = 0;
// A flag to indicate that some transmission error occurred.
volatile bool g_bErrFlag = 0;
// This function sets up UART0 to be used for a console to display information
// as the example is running.
void
InitConsole(void)
// Enable GPIO port A which is used for UART0 pins.
// TODO: change this to whichever GPIO port you are using.
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
// Configure the pin muxing for UART0 functions on port A0 and A1.
// This step is not necessary if your part does not support pin muxing.
// TODO: change this to select the port/pin you are using.
GPIOPinConfigure(GPIO_PA0_U0RX);
GPIOPinConfigure(GPIO_PA1_U0TX);
// Enable UART0 so that we can configure the clock.
SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0);
// Use the internal 16MHz oscillator as the UART clock source.
UARTClockSourceSet(UART0_BASE, UART_CLOCK_PIOSC);
// Select the alternate (UART) function for these pins.
GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1);
// Initialize the UART for console I/O.
UARTStdioConfig(0, 115200, 16000000);
// This function provides a 1 second delay using a simple polling method.
void
SimpleDelay(void)
// Delay cycles for 1 second
SysCtlDelay(16000000 / 3);
// This function is the interrupt handler for the CAN peripheral. It checks
// for the cause of the interrupt, and maintains a count of all messages that
// have been transmitted.
void
CANIntHandler(void)
uint32_t ui32Status;
// Read the CAN interrupt status to find the cause of the interrupt
ui32Status = CANIntStatus(CAN0_BASE, CAN_INT_STS_CAUSE);
// If the cause is a controller status interrupt, then get the status
if(ui32Status == CAN_INT_INTID_STATUS)
// Read the controller status. This will return a field of status
// error bits that can indicate various errors. Error processing
// is not done in this example for simplicity. Refer to the
// API documentation for details about the error status bits.
// The act of reading this status will clear the interrupt. If the
// CAN peripheral is not connected to a CAN bus with other CAN devices
// present, then errors will occur and will be indicated in the
// controller status.
ui32Status = CANStatusGet(CAN0_BASE, CAN_STS_CONTROL);
// Set a flag to indicate some errors may have occurred.
g_bErrFlag = 1;
// Check if the cause is message object 1, which what we are using for
// sending messages.
else if(ui32Status == 1)
// Getting to this point means that the TX interrupt occurred on
// message object 1, and the message TX is complete. Clear the
// message object interrupt.
CANIntClear(CAN0_BASE, 1);
// Increment a counter to keep track of how many messages have been
// sent. In a real application this could be used to set flags to
// indicate when a message is sent.
g_ui32MsgCount++;
// Since the message was sent, clear any error flags.
g_bErrFlag = 0;
// Otherwise, something unexpected caused the interrupt. This should
// never happen.
else
// Spurious interrupt handling can go here.
// Configure the CAN and enter a loop to transmit periodic CAN messages.
int
main(void)
#if defined(TARGET_IS_TM4C129_RA0) || \
defined(TARGET_IS_TM4C129_RA1) || \
defined(TARGET_IS_TM4C129_RA2)
uint32_t ui32SysClock;
#endif
tCANMsgObject sCANMessage;
uint32_t ui32MsgData;
uint8_t *pui8MsgData;
pui8MsgData = (uint8_t *)&ui32MsgData;
// Set the clocking to run directly from the external crystal/oscillator.
// TODO: The SYSCTL_XTAL_ value must be changed to match the value of the
// crystal on your board.
ui32SysClock = SysCtlClockFreqSet((SYSCTL_XTAL_25MHZ |
SYSCTL_OSC_MAIN |
SYSCTL_USE_OSC)
25000000);
#else
SysCtlClockSet(SYSCTL_SYSDIV_4 | SYSCTL_USE_PLL | SYSCTL_XTAL_16MHZ | SYSCTL_OSC_MAIN);
#endif
// Set up the serial console to use for displaying messages. This is
// just for this example program and is not needed for CAN operation.
InitConsole();
// For this example CAN0 is used with RX and TX pins on port B4 and B5.
// The actual port and pins used may be different on your part, consult
// the data sheet for more information.
// GPIO port B needs to be enabled so these pins can be used.
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOB);
// Configure the GPIO pin muxing to select CAN0 functions for these pins.
// This step selects which alternate function is available for these pins.
// This is necessary if your part supports GPIO pin function muxing.
// Consult the data sheet to see which functions are allocated per pin.
GPIOPinConfigure(GPIO_PB4_CAN0RX);
GPIOPinConfigure(GPIO_PB5_CAN0TX);
// Enable the alternate function on the GPIO pins. The above step selects
// which alternate function is available. This step actually enables the
// alternate function instead of GPIO for these pins.
// TODO: change this to match the port/pin you are using
GPIOPinTypeCAN(GPIO_PORTB_BASE, GPIO_PIN_4 | GPIO_PIN_5);
// The GPIO port and pins have been set up for CAN. The CAN peripheral
// must be enabled.
SysCtlPeripheralEnable(SYSCTL_PERIPH_CAN0);
// Initialize the CAN controller
CANInit(CAN0_BASE);
// Set up the bit rate for the CAN bus. This function sets up the CAN
// bus timing for a nominal configuration. You can achieve more control
// over the CAN bus timing by using the function CANBitTimingSet() instead
// of this one, if needed.
// In this example, the CAN bus is set to 500 kHz. In the function below,
// the call to SysCtlClockGet() or ui32SysClock is used to determine the
// clock rate that is used for clocking the CAN peripheral. This can be
// replaced with a fixed value if you know the value of the system clock,
// saving the extra function call. For some parts, the CAN peripheral is
// clocked by a fixed 8 MHz regardless of the system clock in which case
// the call to SysCtlClockGet() or ui32SysClock should be replaced with
// 8000000. Consult the data sheet for more information about CAN
// peripheral clocking.
CANBitRateSet(CAN0_BASE, ui32SysClock, 500000);
#else
CANBitRateSet(CAN0_BASE, SysCtlClockGet(), 500000);
#endif
// Enable interrupts on the CAN peripheral. This example uses static
// allocation of interrupt handlers which means the name of the handler
// is in the vector table of startup code. If you want to use dynamic
// allocation of the vector table, then you must also call CANIntRegister()
// here.
// CANIntRegister(CAN0_BASE, CANIntHandler); // if using dynamic vectors
CANIntEnable(CAN0_BASE, CAN_INT_MASTER | CAN_INT_ERROR | CAN_INT_STATUS);
// Enable the CAN interrupt on the processor (NVIC).
IntEnable(INT_CAN0);
// Enable the CAN for operation.
CANEnable(CAN0_BASE);
// Initialize the message object that will be used for sending CAN
// messages. The message will be 4 bytes that will contain an incrementing
// value. Initially it will be set to 0.
ui32MsgData = 0;
sCANMessage.ui32MsgID = 1;
sCANMessage.ui32MsgIDMask = 0;
sCANMessage.ui32Flags = MSG_OBJ_TX_INT_ENABLE;
sCANMessage.ui32MsgLen = sizeof(pui8MsgData);
sCANMessage.pui8MsgData = pui8MsgData;
// Enter loop to send messages. A new message will be sent once per
// second. The 4 bytes of message content will be treated as an uint32_t
// and incremented by one each time.
while(1)
// Print a message to the console showing the message count and the
// contents of the message being sent.
UARTprintf("Sending msg: 0x%02X %02X %02X %02X",
pui8MsgData[0], pui8MsgData[1], pui8MsgData[2],
pui8MsgData[3]);
// Send the CAN message using object number 1 (not the same thing as
// CAN ID, which is also 1 in this example). This function will cause
// the message to be transmitted right away.
CANMessageSet(CAN0_BASE, 1, &sCANMessage, MSG_OBJ_TYPE_TX);
// Now wait 1 second before continuing
SimpleDelay();
// Check the error flag to see if errors occurred
if(g_bErrFlag)
UARTprintf(" error - cable connected?\n");
else
// If no errors then print the count of message sent
UARTprintf(" total count = %u\n", g_ui32MsgCount);
// Increment the value in the message data.
ui32MsgData++;
// Return no errors
return(0);
// simple_rx.c - Example demonstrating simple CAN message reception.
// are met:
// distribution.
#include <stdint.h>
//! <h1>Simple CAN RX (simple_rx)</h1>
//! This example shows the basic setup of CAN in order to receive messages
//! from the CAN bus. The CAN peripheral is configured to receive messages
//! with any CAN ID and then print the message contents to the console.
//! - GPIO port B peripheral (for CAN0 pins)
//! - CAN0RX - PB4
//! - CAN0TX - PB5
//! - UART0RX - PA0
//! - UART0TX - PA1
//! vector table.
// A counter that keeps track of the number of times the RX interrupt has
// occurred, which should match the number of messages that were received.
// A flag for the interrupt handler to indicate that a message was received.
volatile bool g_bRXFlag = 0;
// A flag to indicate that some reception error occurred.
void
InitConsole(void)
// have been received.
void hardware_init(void)
//Set CPU Clock to 40MHz. 400MHz PLL/2 = 200 DIV 5 = 40MHz
SysCtlClockSet(SYSCTL_SYSDIV_5|SYSCTL_USE_PLL|SYSCTL_XTAL_16MHZ|SYSCTL_OSC_MAIN);
// ADD Tiva-C GPIO setup - enables port, sets pins 1-3 (RGB) pins for output
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);
GPIOPinTypeGPIOOutput(GPIO_PORTF_BASE, GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3);
// Turn on the LED
GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3, 4);
void
CANIntHandler(void)
hardware_init();
//hardware_init();
g_bErrFlag = 1;
// receiving messages.
// Getting to this point means that the RX interrupt occurred on
// message object 1, and the message reception is complete. Clear the
// received. In a real application this could be used to set flags to
// indicate when a message is received.
g_ui32MsgCount++;
// Set flag to indicate received message is pending.
g_bRXFlag = 1;
// Since a message was received, clear any error flags.
g_bErrFlag = 0;
// never happen.
else
// hardware_init(); // Spurious interrupt handling can go here.
// Configure the CAN and enter a loop to receive CAN messages.
int
main(void)
#endif
uint8_t pui8MsgData[8];
// crystal used on your board.
SYSCTL_OSC_MAIN |
SYSCTL_USE_OSC)
25000000);
#else
#endif
InitConsole();
// SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE);
//GPIOPinConfigure(GPIO_PE4_CAN0RX);
//GPIOPinConfigure(GPIO_PE5_CAN0TX);
// must be enabled.
CANInit(CAN0_BASE);
#else
#endif
// here.
//hardware_init();
// Initialize a message object to be used for receiving CAN messages with
// any CAN ID. In order to receive any CAN ID, the ID and mask must both
// be set to 0, and the ID filter enabled.
sCANMessage.ui32MsgID = 0;
sCANMessage.ui32Flags = MSG_OBJ_RX_INT_ENABLE | MSG_OBJ_USE_ID_FILTER;
//sCANMessage.ui32Flags = MSG_OBJ_RX_INT_ENABLE ;
sCANMessage.ui32MsgLen = 8;
// Now load the message object into the CAN peripheral. Once loaded the
// CAN will receive any message on the bus, and an interrupt will occur.
// Use message object 1 for receiving messages (this is not the same as
// the CAN ID which can be any value in this example).
CANMessageSet(CAN0_BASE, 1, &sCANMessage, MSG_OBJ_TYPE_RX);
//hardware_init();
// Enter loop to process received messages. This loop just checks a flag
// that is set by the interrupt handler, and if set it reads out the
// message and displays the contents. This is not a robust method for
// processing incoming CAN data and can only handle one messages at a time.
// If many messages are being received close together, then some messages
// may be dropped. In a real application, some other method should be used
// for queuing received messages in a way to ensure they are not lost. You
// can also make use of CAN FIFO mode which will allow messages to be
// buffered before they are processed.
for(;;)
unsigned int uIdx;
// If the flag is set, that means that the RX interrupt occurred and
// there is a message ready to be read from the CAN
//hardware_init();
if(g_bRXFlag)
// Reuse the same message object that was used earlier to configure
// the CAN for receiving messages. A buffer for storing the
// received data must also be provided, so set the buffer pointer
// within the message object.
// Read the message from the CAN. Message object number 1 is used
// (which is not the same thing as CAN ID). The interrupt clearing
// flag is not set because this interrupt was already cleared in
// the interrupt handler.
CANMessageGet(CAN0_BASE, 1, &sCANMessage, 0);
// Clear the pending message flag so that the interrupt handler can
// set it again when the next message arrives.
g_bRXFlag = 0;
// Check to see if there is an indication that some messages were
// lost.
if(sCANMessage.ui32Flags & MSG_OBJ_DATA_LOST)
UARTprintf("CAN message loss detected\n");
// Print out the contents of the message that was received.
UARTprintf("Msg ID=0x%08X len=%u data=0x",
sCANMessage.ui32MsgID, sCANMessage.ui32MsgLen);
for(uIdx = 0; uIdx < sCANMessage.ui32MsgLen; uIdx++)
UARTprintf("%02X ", pui8MsgData[uIdx]);
UARTprintf("total count=%u\n", g_ui32MsgCount);
// Return no errors
return(0);
Putty output :
