Part Number: TMS570LC4357
Other Parts Discussed in Thread: HALCOGEN
This is from an example code provided from Halcogen's folder. Where are the images it references located? I want to see how the Halcogen file is set up to enable interrupts.
/** @example example_mibspi_loopback.c
* This is an example which descibes the steps to create Mibspi Loopback check
* @b Step @b 1:
* Create a new project.
* Navigate: -> File -> New -> Project
* @image html example_createProject.jpg "Figure: Create a new Project"
* @b Step @b 2:
* Configure driver code generation:
* - Enable MIBSPI 1 to 5 driver
* - Disable others
* Navigate: -> TMS570Sxx /RMxx -> Enable Drivers
* @b Step @b 3:
* Enable Interrupts
* - Enable all MIBSPI interrupts in the MIBSPI VIM Channels tab.
* @b Step @b 4:
* Configure MIBSPI
* - Leave the Transfer group configuration as default
* @image html example_mibspi_config.jpg "Figure: Configure MIBSPI"
* @b Step @b 5:
* Generate code
* Navigate: -> File -> Generate Code
* @image html generateCode.jpg "Figure: Generate Code"
* @b Step @b 6:
* Copy the source code below into your sys_main.c (or) replace sys_main.c with this file.
* The example file example_mibspi_loopback.c can also be found in the examples folder: ../HALCoGen/examples
* @note HALCoGen generates an empty main function in sys_main.c.
-Will
