Part Number: TM4C123GH6PM
Can I obtain a 5 v output from any gpio pin ? Or should I use an external amplifier?I want to operate a relay
cb1_mobile said:(for spike reduction - depending upon the size/power of the relay - you may want to install a diode across the relay's coil - to clamp the spike to the relay's (+) supply voltage. (diode's cathode ties to that (+V.))
And either a reversed zener or resistor in series with that diode.
A relay manufacturer has published a a whitepaper showing that a relays life is reduced if only a diode is used.
Robert
