Part Number: RM46L430
Hello All,
SL_SelfTest_VIM does not remove the injected fault.
If the test is run with interrupts enabled (i.e. a periodic test), then it get stuck in an endless interrupt loop.
If the parity control is temporarily disabled, then the test runs and passes.
If the test pass with the parity interrupt disabled, then what does the VIM_SRAM_PARITY_TEST actually test?
Mark.
