RTOS/TM4C1294NCPDT: tirtos
Part Number: TM4C1294NCPDT
Tool/software: TI-RTOS
i wrote 1 timer with 200 msec its called to swi  from their its calling task(through semaphore ) --->task consist SD_SPI operation its WRITING  DATA EVERT 200ms ..5 mins once i like to close the file and i want create new file ...................i wrote some routine its creating files its writing data to first file only remaining file are creating but data not writing.
 * Copyright (c) 2015, Texas Instruments Incorporated
 * All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met:
 * *  Redistributions of source code must retain the above copyright
 * *  Redistributions in binary form must reproduce the above copyright
 *    documentation and/or other materials provided with the distribution.
 * *  Neither the name of Texas Instruments Incorporated nor the names of
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
 * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
 * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
 * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
 * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
 * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
 * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
 * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 *  ======== fatsd.c ========
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <stdbool.h>
/* XDCtools Header files */
#include <xdc/std.h>
#include <xdc/runtime/System.h>
/* BIOS Header files */
#include <ti/sysbios/BIOS.h>
#include <ti/sysbios/knl/Clock.h>
#include <ti/sysbios/knl/Task.h>
#include <ti/sysbios/knl/Swi.h>
#include <ti/sysbios/knl/Semaphore.h>
/* TI-RTOS Header files */
#include <ti/drivers/GPIO.h>
#include <ti/drivers/SDSPI.h>
#include <ti/drivers/SPI.h>
#include <ti/sysbios/hal/Seconds.h>
#include <time.h>
/* Example/Board Header files */
#include "Board.h"
/* Buffer size used for the file copy process */
#ifndef CPY_BUFF_SIZE
#define CPY_BUFF_SIZE       2048
#endif
/* String conversion macro */
#define STR_(n)             #n
#define STR(n)              STR_(n)
/* Drive number used for FatFs */
#define DRIVE_NUM           0
#define SPI_MSG_LENGTH    16
#define TASKSTACKSIZE       768
char inputfile[40] = "fat:"STR(DRIVE_NUM)":input.txt";
char outputfile[] = "fat:"STR(DRIVE_NUM)":output.txt";
const char textarray[] = "@Ch0:0,Ch1:1,Ch2:2,Ch3:3,Ch4:4,Ch5:5,Ch6:6,Ch7:7#\n";
int init_spi = 0;
UInt32 sleepTickCount;
unsigned char cpy_buff[CPY_BUFF_SIZE + 1];
Task_Struct task0Struct;
Char task0Stack[TASKSTACKSIZE];
Char task1Stack[TASKSTACKSIZE];
Swi_Struct swi0Struct, swi1Struct;
Swi_Handle swi0Handle, swi1Handle;
Semaphore_Struct semStruct;
Semaphore_Handle semHandle;
char strTime[40];
char filename[20];
int count = 0;
void ReadChnData()
    count++;
    Swi_post(swi0Handle);
 *  ======== swi0Fxn =======
Void swi0Fxn(UArg arg0, UArg arg1)
    System_printf("count : %d\n", count);
    System_flush();
    Semaphore_post(semHandle);
 *  ======== swi1Fxn =======
Void swi1Fxn(UArg arg0, UArg arg1)
    System_printf("Enter swi1Fxn, a0 = %d, a1 = %d\n", (Int) arg0, (Int) arg1);
    System_printf("swi1 trigger = %d\n", Swi_getTrigger());
    System_printf("swi1 pri = %d\n", Swi_getPri(swi1Handle));
    System_printf("Exit swi1Fxn\n");
    System_flush();
    //  Semaphore_post(sem0Handle);
void GetStrTime(char *buff1)
    time_t now;
    struct tm ts;
    char buff[40];
    /* Set the current time in seconds since epoch*/
    Seconds_set(1500654672);
    time(&now);
    // Format time, "ddd yyyy-mm-dd hh:mm:ss zzz"
    ts = *localtime(&now);
    strftime(buff, 30, "%m%d%H%M", &ts);
    strncpy(buff1, buff, sizeof(buff));
void SDcardoperation()
    SDSPI_Handle sdspiHandle;
    SDSPI_Params sdspiParams;
    int numberofbytes;
    GetStrTime(strTime);
    strcpy(tempstr, inputfile);
    sprintf(filename, "%s.txt", strTime);
    strcat(tempstr, filename);
    printf("%s\n", tempstr);
    SDSPI_Params_init(&sdspiParams);
    sdspiHandle = SDSPI_open(Board_SDSPI0, DRIVE_NUM, &sdspiParams);
    if (sdspiHandle == NULL)
        System_abort("Error starting the SD card\n");
    else
        System_printf("Drive %u is mounted\n", DRIVE_NUM);
    src = fopen(tempstr, "a+");
    if (src != NULL)
        for (;;)
            Semaphore_pend(semHandle, BIOS_WAIT_FOREVER);
            numberofbytes = fwrite(textarray, 1, strlen(textarray), src);
            fflush(src);
            // Semaphore_post(semHandle);
            Task_sleep(sleepTickCount);
            System_printf("done\n");
            System_flush();
            count1++;
              if (numberofbytes == strlen(textarray))
             System_printf("numberofbytes : %d \n", numberofbytes);
             System_flush();
            if (count1 >= 300)
                count2++;
                fclose(src);
                src =NULL;
                SDSPI_close(sdspiHandle);
                System_printf("Drive %u unmounted\n", DRIVE_NUM);
                System_flush();
                GPIO_write(Board_LED0, Board_LED_OFF);
                count1 = 0;
                memset(filename, 0, 20);
                //BIOS_exit(0);
                memset(tempstr, 0, sizeof(tempstr));
                System_printf("Filename :%s \n", tempstr);
                else
                if (src != NULL)
                    System_printf("Opening \n");
                else
                    System_printf("Opening error \n");
                if(count2 >= 2){
                    BIOS_exit(0);
 *  ======== main ========
int main(void)
    Task_Params taskParams;
    Semaphore_Params semParams;
    Swi_Params swiParams;
    /* Call board init functions */
    Board_initGeneral();
    Board_initGPIO();
    Board_initSDSPI();
    //Fat_sd_init();
    /* Construct file copy Task thread */
    Task_Params_init(&taskParams);
    taskParams.stackSize = TASKSTACKSIZE;
    taskParams.stack = &task0Stack;
    Task_construct(&task0Struct, (Task_FuncPtr) SDcardoperation, &taskParams, NULL);
    Swi_Params_init(&swiParams);
    swiParams.arg0 = 1;
    swiParams.arg1 = 0;
    swiParams.priority = 2;
    swiParams.trigger = 2;
    Swi_construct(&swi0Struct, (Swi_FuncPtr) swi0Fxn, &swiParams, NULL);
    swi0Handle = Swi_handle(&swi0Struct);
    swiParams.arg0 = 2;
    swiParams.arg1 = 0;
    swiParams.priority = 1;
    swiParams.trigger = 3;
    Swi_construct(&swi1Struct, (Swi_FuncPtr) swi1Fxn, &swiParams, NULL);
    swi1Handle = Swi_handle(&swi1Struct);
    /* Construct a Semaphore object to be use as a resource lock, inital count 1 */
    Semaphore_Params_init(&semParams);
    Semaphore_construct(&semStruct, 1, &semParams);
    /* Obtain instance handle */
    semHandle = Semaphore_handle(&semStruct);
    /* We want to sleep for 10000 microseconds */
    sleepTickCount = 10000 / Clock_tickPeriod;
    /* Turn on user LED */
    GPIO_write(Board_LED0, Board_LED_ON);
    System_printf("Starting the FatSD example\n");
    /* Start BIOS */
    BIOS_start();
    return (0);
  • Hello Kota,
    Can you give the output you are seeing? That would help me to understand what your problem is. Also, what version of TI-RTOS are you using?
    Todd
  • HI,
    Thanks for helping
    i have sd card interfaced with SPI and i want  to write a data in .txt file .....................my dought is every 200ms once i am opening spi handler AND opening text file and writing data closing txt file and spi handler is it write way of doing once if u check my previous msg u can find once .c file pls check once i wrote some routine ..
    Rajesh.K
