Part Number: TM4C123GH6PM
Other Parts Discussed in Thread: CC3100
Hello everyone,
Currently I am working on CC3100 and Tiva C series TM4C123GH6PM. I imported the p2p example from CC3100 sdk 1.2.0. I got no errors and loaded the program successfully. But when I run the program I cannot see any thing in the TeraTerm window as well as in the Wireless Network Connection window I cannot see "cc3100-p2p-device". I have attached the file below.
Can anyone tell me what is the problem?
* main.c - sample application for using P2P
* Copyright (C) 2014 Texas Instruments Incorporated - http://www.ti.com/
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* Application Name - P2P
* Application Overview - This is a sample application demonstrating how CC3100 can be
* connected to a P2P device.
* Application Details - http://processors.wiki.ti.com/index.php/CC31xx_P2P_Application
* doc\examples\p2p.pdf
#include "simplelink.h"
#include "sl_common.h"
#include "driverlib/rom.h"
#define APPLICATION_VERSION "1.2.0"
#define SL_STOP_TIMEOUT 0xFF
#define P2P_REMOTE_DEVICE "DIRECT-" /* Dummy SSDI to start the p2p connection */
#define P2P_DEVICE_NAME "cc3100-p2p-device"
#define DEVICE_TYPE "1-0050F204-1"
#define SECURITY_TYPE SL_SEC_TYPE_P2P_PBC
#define KEY ""
#define LISTEN_CHANNEL 11
#define OPRA_CHANNEL 6
#define REGULATORY_CLASS 81
/* Port to be used by TCP server*/
#define PORT_NUM 5001
#define BUF_SIZE 1400
#define NO_OF_PACKETS 1000
/* Application specific status/error codes */
typedef enum{
DEVICE_NOT_IN_STATION_MODE = -0x7D0, /* Choosing this number to avoid overlap w/ host-driver's error codes */
P2P_CONNECTION_FAILED = DEVICE_NOT_IN_STATION_MODE -1,
TCP_RECV_ERROR = P2P_CONNECTION_FAILED - 1,
STATUS_CODE_MAX = -0xBB8
}e_AppStatusCodes;
* GLOBAL VARIABLES -- Start
_u8 g_Status = 0;
_u32 g_DeviceIp = 0;
_i8 g_p2p_dev[MAXIMAL_SSID_LENGTH + 1];
union
_u8 BsdBuf[BUF_SIZE];
_u32 demobuf[BUF_SIZE/4];
} uBuf;
const _u8 digits[] = "0123456789";
* GLOBAL VARIABLES -- End
* STATIC FUNCTION DEFINITIONS -- Start
static _i32 configureSimpleLinkToDefaultState();
static _i32 initializeAppVariables();
static _u8 itoa(_i16 cNum, _u8 *cString);
static _i32 DisplayIP();
static _i32 establishConnectionWithP2Pdevice();
static _i32 BsdTcpServer(_u16 Port);
static void displayBanner();
* STATIC FUNCTION DEFINITIONS -- End
* ASYNCHRONOUS EVENT HANDLERS -- Start
\brief This function handles WLAN events
\param[in] pWlanEvents is the event passed to the handler
\return none
\note
\warning
void SimpleLinkWlanEventHandler(SlWlanEvent_t *pWlanEvent)
if(pWlanEvent == NULL)
CLI_Write(" [WLAN EVENT] NULL Pointer Error \n\r");
return;
switch(pWlanEvent->Event)
case SL_WLAN_CONNECT_EVENT:
* Information about the connected AP (like name, MAC etc) will be
* available in 'slWlanConnectAsyncResponse_t' - Applications
* can use it if required
* slWlanConnectAsyncResponse_t *pEventData = NULL;
* pEventData = &pWlanEvent->EventData.STAandP2PModeWlanConnected;
SET_STATUS_BIT(g_Status, STATUS_BIT_CONNECTION);
break;
case SL_WLAN_STA_CONNECTED_EVENT:
* Information about the connected STA (like name, MAC etc) will be
* available in 'slPeerInfoAsyncResponse_t' - Applications
* slPeerInfoAsyncResponse_t *pEventData = NULL;
* pEventData = &pWlanEvent->EventData.APModeStaConnected;
SET_STATUS_BIT(g_Status, STATUS_BIT_STA_CONNECTED);
break;
case SL_WLAN_DISCONNECT_EVENT:
* Information about the disconnected STA and reason code will be
* pEventData = &pWlanEvent->EventData.STAandP2PModeDisconnected;
CLR_STATUS_BIT(g_Status, STATUS_BIT_CONNECTION);
CLR_STATUS_BIT(g_Status, STATUS_BIT_IP_ACQUIRED);
break;
case SL_WLAN_STA_DISCONNECTED_EVENT:
* Information about the connected STA (device name, MAC) will be
CLR_STATUS_BIT(g_Status, STATUS_BIT_STA_CONNECTED);
CLR_STATUS_BIT(g_Status, STATUS_BIT_IP_LEASED);
break;
case SL_WLAN_CONNECTION_FAILED_EVENT:
* Status code for connection faliure will be available
* in 'slWlanConnFailureAsyncResponse_t' - Application
* can use it if required.
* slWlanConnFailureAsyncResponse_t *pEventData = NULL;
* pEventData = &pWlanEvent->EventData.P2PModewlanConnectionFailure
SET_STATUS_BIT(g_Status, STATUS_BIT_CONNECTION_FAILED);
break;
case SL_WLAN_P2P_NEG_REQ_RECEIVED_EVENT:
SET_STATUS_BIT(g_Status, STATUS_BIT_P2P_NEG_REQ_RECEIVED);
pal_Memset(g_p2p_dev, '\0', MAXIMAL_SSID_LENGTH + 1);
pal_Memcpy(g_p2p_dev,pWlanEvent->EventData.P2PModeNegReqReceived.go_peer_device_name,
pWlanEvent->EventData.P2PModeNegReqReceived.go_peer_device_name_len);
break;
case SL_WLAN_P2P_DEV_FOUND_EVENT:
* Information about the remote P2P device (device name and MAC)
* will be available in 'slPeerInfoAsyncResponse_t' - Applications
* pEventData = &pWlanEvent->EventData.P2PModeDevFound;
break;
default:
break;
\brief This function handles events for IP address acquisition via DHCP
indication
\param[in] pNetAppEvent is the event passed to the handler
\return None
\note
\warning
void SimpleLinkNetAppEventHandler(SlNetAppEvent_t *pNetAppEvent)
if(pNetAppEvent == NULL)
CLI_Write(" [NETAPP EVENT] NULL Pointer Error \n\r");
return;
switch( pNetAppEvent->Event )
case SL_NETAPP_IPV4_IPACQUIRED_EVENT:
SlIpV4AcquiredAsync_t *pEventData = NULL;
pEventData = &pNetAppEvent->EventData.ipAcquiredV4;
g_DeviceIp = pEventData->ip;
SET_STATUS_BIT(g_Status, STATUS_BIT_IP_ACQUIRED);
break;
case SL_NETAPP_IP_LEASED_EVENT:
* Information about the connection (like leased IP, lease time etc)
* will be available in 'SlIpLeasedAsync_t'
* Applications can use it if required
* SlIpLeasedAsync_t *pEventData = NULL;
* pEventData = &pNetAppEvent->EventData.ipLeased;
SET_STATUS_BIT(g_Status, STATUS_BIT_IP_LEASED);
break;
default:
CLI_Write(" [NETAPP EVENT] Unexpected event \n\r");
break;
\brief This function handles callback for the HTTP server events
\param[in] pHttpEvent - Contains the relevant event information
\param[in] pHttpResponse - Should be filled by the user with the
relevant response information
\return None
\note
\warning
void SimpleLinkHttpServerCallback(SlHttpServerEvent_t *pHttpEvent,
SlHttpServerResponse_t *pHttpResponse)
/* Unused in this application */
CLI_Write(" [HTTP EVENT] Unexpected event \n\r");
\brief This function handles general error events indication
\param[in] pDevEvent is the event passed to the handler
\return None
void SimpleLinkGeneralEventHandler(SlDeviceEvent_t *pDevEvent)
* Most of the general errors are not FATAL are are to be handled
* appropriately by the application
CLI_Write(" [GENERAL EVENT] \n\r");
\brief This function handles socket events indication
\param[in] pSock is the event passed to the handler
\return None
void SimpleLinkSockEventHandler(SlSockEvent_t *pSock)
if(pSock == NULL)
CLI_Write(" [SOCK EVENT] NULL Pointer Error \n\r");
return;
switch( pSock->Event )
case SL_SOCKET_TX_FAILED_EVENT:
* TX Failed
* Information about the socket descriptor and status will be
* available in 'SlSockEventData_t' - Applications can use it if
* required
* SlSockEventData_u *pEventData = NULL;
* pEventData = & pSock->socketAsyncEvent;
switch( pSock->socketAsyncEvent.SockTxFailData.status )
case SL_ECLOSE:
CLI_Write(" [SOCK EVENT] Close socket operation failed to transmit all queued packets\n\r");
break;
default:
CLI_Write(" [SOCK EVENT] Unexpected event \n\r");
break;
break;
default:
break;
* ASYNCHRONOUS EVENT HANDLERS -- End
* Application's entry point
int main(int argc, char** argv)
_u8 paramBuff[4];
_i32 retVal = -1;
retVal = initializeAppVariables();
ASSERT_ON_ERROR(retVal);
/* Stop WDT and initialize the system-clock of the MCU
These functions needs to be implemented in PAL */
stopWDT();
initClk();
/* Initialize the Application Uart Interface */
CLI_Configure();
displayBanner();
* Following function configures the device to default state by cleaning
* the persistent settings stored in NVMEM (viz. connection profiles &
* policies, power policy etc)
* Applications may choose to skip this step if the developer is sure
* that the device is in its default state at start of application
* Note that all profiles and persistent settings that were done on the
* device will be lost
retVal = configureSimpleLinkToDefaultState();
if(retVal < 0)
if (DEVICE_NOT_IN_STATION_MODE == retVal)
CLI_Write(" Failed to configure the device in its default state \n\r");
LOOP_FOREVER();
CLI_Write(" Device is configured in default state \n\r");
* Assumption is that the device is configured in station mode already
* and it is in its default state
/* Initializing the CC3100 device */
retVal = sl_Start(0, 0, 0);
if ((retVal < 0) ||
(ROLE_STA != retVal) )
CLI_Write(" Failed to start the device \n\r");
LOOP_FOREVER();
CLI_Write(" Configuring device in P2P mode\r\n");
/* Configure P2P mode */
retVal = sl_WlanSetMode(ROLE_P2P);
if(retVal < 0)
LOOP_FOREVER();
/* Set Auto policy
* any p2p option (SL_CONNECTION_POLICY(0,0,0,any_p2p,0)) can be used to
* connect to first available p2p device */
retVal = sl_WlanPolicySet(SL_POLICY_CONNECTION,SL_CONNECTION_POLICY(1,0,0,0,0),NULL,0);
if(retVal < 0)
LOOP_FOREVER();
/* Set the negotiation role (SL_P2P_ROLE_NEGOTIATE).
* CC3100 will negotiate with remote device GO/client mode.
* Other valid options are:
* - SL_P2P_ROLE_GROUP_OWNER
* - SL_P2P_ROLE_CLIENT */
retVal = sl_WlanPolicySet(SL_POLICY_P2P, SL_P2P_POLICY(SL_P2P_ROLE_NEGOTIATE,
SL_P2P_NEG_INITIATOR_ACTIVE),NULL,0);
if(retVal < 0)
LOOP_FOREVER();
/* Set P2P Device name */
retVal = sl_NetAppSet(SL_NET_APP_DEVICE_CONFIG_ID, NETAPP_SET_GET_DEV_CONF_OPT_DEVICE_URN,
pal_Strlen(P2P_DEVICE_NAME), (_u8 *)P2P_DEVICE_NAME);
if(retVal < 0)
LOOP_FOREVER();
/* Set P2P device type */
retVal = sl_WlanSet(SL_WLAN_CFG_P2P_PARAM_ID, WLAN_P2P_OPT_DEV_TYPE,
pal_Strlen(DEVICE_TYPE), DEVICE_TYPE);
if(retVal < 0)
LOOP_FOREVER();
paramBuff[0] = LISTEN_CHANNEL;
paramBuff[1] = REGULATORY_CLASS;
paramBuff[2] = OPRA_CHANNEL;
paramBuff[3] = REGULATORY_CLASS;
/* Set P2P Device listen and operation channel valid channels are 1/6/11 */
retVal = sl_WlanSet(SL_WLAN_CFG_P2P_PARAM_ID, WLAN_P2P_OPT_CHANNEL_N_REGS, 4, paramBuff);
if(retVal < 0)
LOOP_FOREVER();
/* Restart as P2P device */
retVal = sl_Stop(SL_STOP_TIMEOUT);
if(retVal < 0)
LOOP_FOREVER();
if ((retVal < 0) ||
(ROLE_P2P != retVal) )
CLI_Write(" Failed to start the device in P2P mode \n\r");
LOOP_FOREVER();
CLI_Write(" Device is configured in P2P mode - Device name: ");
CLI_Write(P2P_DEVICE_NAME);
CLI_Write("\r\n");
/* Connect to configure P2P device */
retVal = establishConnectionWithP2Pdevice();
if(retVal < 0)
CLI_Write(" Failed to establish connection w/ remote P2P device \n\r");
LOOP_FOREVER();
CLI_Write(" Connection established w/ remote P2P device \r\n");
retVal = DisplayIP();
if(retVal < 0)
LOOP_FOREVER();
/*After calling this function, you can start sending data to CC3100 IP
* address on PORT_NUM */
retVal = BsdTcpServer(PORT_NUM);
if(retVal < 0)
CLI_Write(" Failed to start TCP server \n\r");
else
CLI_Write(" TCP client connected successfully \n\r");
/* Stop the CC3100 device */
if(retVal < 0)
LOOP_FOREVER();
return 0;
\brief This function configure the SimpleLink device in its default state. It:
- Sets the mode to STATION
- Configures connection policy to Auto and AutoSmartConfig
- Deletes all the stored profiles
- Enables DHCP
- Disables Scan policy
- Sets Tx power to maximum
- Sets power policy to normal
- Unregisters mDNS services
- Remove all filters
\param[in] none
\return On success, zero is returned. On error, negative is returned
SlVersionFull ver = {0};
_WlanRxFilterOperationCommandBuff_t RxFilterIdMask = {0};
_u8 val = 1;
_u8 configOpt = 0;
_u8 configLen = 0;
_u8 power = 0;
_i32 retVal = -1;
_i32 mode = -1;
mode = sl_Start(0, 0, 0);
ASSERT_ON_ERROR(mode);
/* If the device is not in station-mode, try configuring it in station-mode */
if (ROLE_STA != mode)
if (ROLE_AP == mode)
/* If the device is in AP mode, we need to wait for this event before doing anything */
while(!IS_IP_ACQUIRED(g_Status)) { _SlNonOsMainLoopTask(); }
/* Switch to STA role and restart */
retVal = sl_WlanSetMode(ROLE_STA);
/* Check if the device is in station again */
if (ROLE_STA != retVal)
/* We don't want to proceed if the device is not coming up in station-mode */
ASSERT_ON_ERROR(DEVICE_NOT_IN_STATION_MODE);
/* Get the device's version-information */
configOpt = SL_DEVICE_GENERAL_VERSION;
configLen = sizeof(ver);
retVal = sl_DevGet(SL_DEVICE_GENERAL_CONFIGURATION, &configOpt, &configLen, (_u8 *)(&ver));
/* Set connection policy to Auto + SmartConfig (Device's default connection policy) */
retVal = sl_WlanPolicySet(SL_POLICY_CONNECTION, SL_CONNECTION_POLICY(1, 0, 0, 0, 1), NULL, 0);
/* Remove all profiles */
retVal = sl_WlanProfileDel(0xFF);
* Device in station-mode. Disconnect previous connection if any
* The function returns 0 if 'Disconnected done', negative number if already disconnected
* Wait for 'disconnection' event if 0 is returned, Ignore other return-codes
retVal = sl_WlanDisconnect();
if(0 == retVal)
/* Wait */
while(IS_CONNECTED(g_Status)) { _SlNonOsMainLoopTask(); }
/* Enable DHCP client*/
retVal = sl_NetCfgSet(SL_IPV4_STA_P2P_CL_DHCP_ENABLE,1,1,&val);
/* Disable scan */
configOpt = SL_SCAN_POLICY(0);
retVal = sl_WlanPolicySet(SL_POLICY_SCAN , configOpt, NULL, 0);
/* Set Tx power level for station mode
Number between 0-15, as dB offset from max power - 0 will set maximum power */
power = 0;
retVal = sl_WlanSet(SL_WLAN_CFG_GENERAL_PARAM_ID, WLAN_GENERAL_PARAM_OPT_STA_TX_POWER, 1, (_u8 *)&power);
/* Set PM policy to normal */
retVal = sl_WlanPolicySet(SL_POLICY_PM , SL_NORMAL_POLICY, NULL, 0);
/* Unregister mDNS services */
retVal = sl_NetAppMDNSUnRegisterService(0, 0);
/* Remove all 64 filters (8*8) */
pal_Memset(RxFilterIdMask.FilterIdMask, 0xFF, 8);
retVal = sl_WlanRxFilterSet(SL_REMOVE_RX_FILTER, (_u8 *)&RxFilterIdMask,
sizeof(_WlanRxFilterOperationCommandBuff_t));
return retVal; /* Success */
\brief Opening a server side socket and receiving data
This function opens a TCP socket in Listen mode and waits for an incoming
TCP connection. If a socket connection is established then the function
will try to read 1000 TCP packets from the connected client.
\param[in] port number on which the server will be listening on
\return 0 on success, -1 on Error.
\note This function will wait for an incoming connection till one
is established
\warning
SlSockAddrIn_t Addr;
SlSockAddrIn_t LocalAddr;
_u16 idx = 0;
_u16 AddrSize = 0;
_i16 SockID = 0;
_i32 Status = 0;
_i16 newSockID = 0;
_u16 LoopCount = 0;
_u16 recvSize = 0;
for (idx=0 ; idx<BUF_SIZE ; idx++)
uBuf.BsdBuf[idx] = (_u8)(idx % 10);
LocalAddr.sin_family = SL_AF_INET;
LocalAddr.sin_port = sl_Htons((_u16)Port);
LocalAddr.sin_addr.s_addr = 0;
SockID = sl_Socket(SL_AF_INET,SL_SOCK_STREAM, 0);
if( SockID < 0 )
CLI_Write(" [TCP Server] Create socket Error \n\r");
ASSERT_ON_ERROR(SockID);
AddrSize = sizeof(SlSockAddrIn_t);
Status = sl_Bind(SockID, (SlSockAddr_t *)&LocalAddr, AddrSize);
if( Status < 0 )
sl_Close(SockID);
CLI_Write(" [TCP Server] Socket address assignment Error \n\r");
ASSERT_ON_ERROR(Status);
Status = sl_Listen(SockID, 0);
if( Status < 0 )
sl_Close(SockID);
CLI_Write(" [TCP Server] Listen Error \n\r");
newSockID = sl_Accept(SockID, ( struct SlSockAddr_t *)&Addr,
(SlSocklen_t*)&AddrSize);
if( newSockID < 0 )
sl_Close(SockID);
CLI_Write(" [TCP Server] Accept connection Error \n\r");
ASSERT_ON_ERROR(newSockID);
while (LoopCount < NO_OF_PACKETS)
recvSize = BUF_SIZE;
do
Status = sl_Recv(newSockID, &uBuf.BsdBuf[BUF_SIZE - recvSize], recvSize, 0);
if( Status <= 0 )
sl_Close(newSockID);
sl_Close(SockID);
CLI_Write(" [TCP Server] Data recv Error \n\r");
ASSERT_ON_ERROR(TCP_RECV_ERROR);
recvSize -= Status;
}while(recvSize > 0);
LoopCount++;
Status = sl_Close(newSockID);
Status = sl_Close(SockID);
return SUCCESS;
\brief Connecting to a remote p2p device
This function connects to the required p2p device (P2P_REMOTE_DEVICE).
This code example connects using key (KEY).
\param[in] None
\return None
\note
\warning
SlSecParams_t secParams = {0};
_i32 retVal = 0;
secParams.Key = KEY;
secParams.KeyLen = pal_Strlen(KEY);
secParams.Type = SECURITY_TYPE;
/* wlan connect call with dummy SSID to start the connection process */
retVal = sl_WlanConnect(P2P_REMOTE_DEVICE, pal_Strlen(P2P_REMOTE_DEVICE), 0, &secParams, 0);
while(!IS_P2P_NEG_REQ_RECEIVED(g_Status))
/* Connect with the device requesting the connection */
retVal = sl_WlanConnect(g_p2p_dev, pal_Strlen(g_p2p_dev), 0, &secParams, 0);
while ((!IS_IP_LEASED(g_Status) && !IS_IP_ACQUIRED(g_Status)) ||
(!IS_CONNECTED(g_Status) && !IS_STA_CONNECTED(g_Status)))
if(IS_CONNECTION_FAILED(g_Status))
/* Error, connection is failed */
CLI_Write((_u8 *)" Connection Failed\r\n");
ASSERT_ON_ERROR(P2P_CONNECTION_FAILED);
return SUCCESS;
\brief Display the IP Adderess of device
\param[in] none
\return none
\note
\warning
_i32 retVal = -1;
SlNetCfgIpV4Args_t ipV4 = {0};
_u8 buff[18] = {'\0'};
_u8 *ccPtr = 0;
_u8 ccLen = 0;
_u8 len = sizeof(SlNetCfgIpV4Args_t);
_u8 dhcpIsOn = 0;
ccPtr = buff;
if(IS_IP_LEASED(g_Status))
/* Device is in GO mode, Get the IP of Device */
retVal = sl_NetCfgGet(SL_IPV4_AP_P2P_GO_GET_INFO,&dhcpIsOn,&len,(_u8 *)&ipV4);
g_DeviceIp = ipV4.ipV4;
ccLen = itoa((_u8)SL_IPV4_BYTE(g_DeviceIp,3), ccPtr);
ccPtr += ccLen;
*ccPtr++ = '.';
ccLen = itoa((_u8)SL_IPV4_BYTE(g_DeviceIp,2), ccPtr);
ccPtr += ccLen;
*ccPtr++ = '.';
ccLen = itoa((_u8)SL_IPV4_BYTE(g_DeviceIp,1), ccPtr);
ccPtr += ccLen;
*ccPtr++ = '.';
ccLen = itoa((_u8)SL_IPV4_BYTE(g_DeviceIp,0), ccPtr);
ccPtr += ccLen;
CLI_Write((_u8 *)" Device IP: ");
CLI_Write((_u8 *)buff);
CLI_Write((_u8 *)"\r\n");
return SUCCESS;
\brief Convert integer to ASCII in decimal base
\param[in] cNum - input integer number to convert
\param[in] cString - pointer to output string
\return number of ASCII characters
\note
\warning
_u8* ptr = 0;
_i16 uTemp = cNum;
_u8 length = 0;
/* value 0 is a special case */
if (cNum == 0)
length = 1;
*cString = '0';
return length;
/* Find out the length of the number, in decimal base */
while (uTemp > 0)
uTemp /= 10;
length++;
/* Do the actual formatting, right to left */
uTemp = cNum;
ptr = cString + length;
while (uTemp > 0)
--ptr;
*ptr = digits[uTemp % 10];
uTemp /= 10;
return length;
\brief This function initializes the application variables
\param[in] None
\return 0 on success, negative error-code on error
g_Status = 0;
g_DeviceIp = 0;
pal_Memset(uBuf.BsdBuf, 0, sizeof(uBuf));
pal_Memset(g_p2p_dev, 0, MAXIMAL_SSID_LENGTH + 1);
return SUCCESS;
\brief This function displays the application's banner
\param None
\return None
CLI_Write("\n\r\n\r");
CLI_Write(" P2P Application - Version ");
CLI_Write(APPLICATION_VERSION);
CLI_Write("\n\r*******************************************************************************\n\r");
