Part Number: TM4C1294NCPDT
Tool/software: TI-RTOS
I have attached my sample code, if I compile it. The transfer is occurring only once and DMA interrupt is not triggering.
Cant find what mistake I have did.
* Copyright (c) 2015, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* ======== empty.c ========
/* XDCtools Header files */
#include <xdc/std.h>
#include <xdc/runtime/System.h>
/* BIOS Header files */
#include <ti/sysbios/BIOS.h>
#include <ti/sysbios/knl/Task.h>
/* TI-RTOS Header files */
// #include <ti/drivers/EMAC.h>
#include <ti/drivers/GPIO.h>
// #include <ti/drivers/I2C.h>
// #include <ti/drivers/SDSPI.h>
#include <ti/drivers/SPI.h>
// #include <ti/drivers/SSI.h>
// #include <ti/drivers/USBMSCHFatFs.h>
// #include <ti/drivers/Watchdog.h>
// #include <ti/drivers/WiFi.h>
#include <ti/sysbios/knl/Semaphore.h>
/* Board Header file */
#include "Board.h"
#include <ti/sysbios/knl/Swi.h>
#include <xdc/runtime/Error.h>
#include <ti/sysbios/family/arm/m3/Hwi.h>
#include <stdbool.h>
#include "driverlib/sysctl.h"
#include "driverlib/ssi.h"
#include "driverlib/udma.h"
#include "driverlib/interrupt.h"
#include <inc/hw_memmap.h>
#include <inc/hw_ints.h>
#include "inc/hw_ssi.h"
uint8_t pui8ControlTable[1024];
#define TASKSTACKSIZE 512
#define MEM_BUFFER_SIZE 8
#define SSI_TXBUF_SIZE 8
#define SSI_RXBUF_SIZE 8
Task_Struct task0Struct;
uint8_t DMATxBuffer[SSI_TXBUF_SIZE];
uint8_t DMAPrimary_Buffer[SSI_RXBUF_SIZE];
uint8_t DMASecondary_Buffer[SSI_RXBUF_SIZE];
Char task0Stack[TASKSTACKSIZE];
bool SPI_Master;
uint8_t ActivePage = 1;
//static uint32_t g_ui32MemXferCount = 0;
uint32_t g_ui32uDMAErrCount = 0;
uint32_t g_ui32BadISR = 0;
uint32_t g_ui32SrcBuf[MEM_BUFFER_SIZE];
uint32_t g_ui32DstBuf[MEM_BUFFER_SIZE];
bool transferOK = FALSE;
* ======== heartBeatFxn ========
* Toggle the Board_LED0. The Task_sleep is determined by arg0 which
* is configured for the heartBeat Task instance.
uint32_t DMAtransferCount;
// The interrupt handler for uDMA errors. This interrupt will occur if the
// uDMA encounters a bus error while trying to perform a transfer. This
// handler just increments a counter if an error occurs.
void
uDMAErrorHandler(void)
uint32_t ui32Status;
// Check for uDMA error bit
ui32Status = uDMAErrorStatusGet();
// If there is a uDMA error, then clear the error and increment
// the error counter.
if(ui32Status)
uDMAErrorStatusClear();
g_ui32uDMAErrCount++;
// The interrupt handler for uDMA interrupts from the memory channel. This
// interrupt will increment a counter, and then restart another memory
// transfer.
void
uDMAIntHandler(void)
uint32_t ui32Mode;
GPIO_toggle(Board_LED1);
// Check for the primary control structure to indicate complete.
ui32Mode = uDMAChannelModeGet(UDMA_CHANNEL_SW);
if(ui32Mode == UDMA_MODE_STOP)
// Configure it for another transfer.
uDMAChannelTransferSet(UDMA_CHANNEL_SW, UDMA_MODE_AUTO,
g_ui32SrcBuf, g_ui32DstBuf,
MEM_BUFFER_SIZE);
// Initiate another transfer.
uDMAChannelEnable(UDMA_CHANNEL_SW);
uDMAChannelRequest(UDMA_CHANNEL_SW);
// If the channel is not stopped, then something is wrong.
else
g_ui32BadISR++;
// The interrupt handler for SSI0.
void SSI0IntHandler(void)
uint32_t ulMode;
// Read the interrupt status of the SSI.
ui32Status = SSIIntStatus(SSI0_BASE, TRUE);
// Clear any pending status, even though there should be none since no SSI
// interrupts were enabled. If SSI error interrupts were enabled, then
// those interrupts could occur here and should be handled. Since uDMA is
// used for both the RX and TX, then neither of those interrupts should be
// enabled.
SSIIntClear(SSI0_BASE, ui32Status);
ulMode = uDMAChannelModeGet(UDMA_CHANNEL_SSI0RX | UDMA_ALT_SELECT);
if(ulMode == UDMA_MODE_STOP) {
// Swap active and background pages
ActivePage = 1;
uDMAChannelTransferSet(UDMA_CHANNEL_SSI0RX | UDMA_ALT_SELECT,
UDMA_MODE_PINGPONG, (void *)(SSI0_BASE + SSI_O_DR),
DMAPrimary_Buffer, SSI_RXBUF_SIZE);
uDMAChannelEnable(UDMA_CHANNEL_SSI0RX);
//check primary channel
ulMode = uDMAChannelModeGet(UDMA_CHANNEL_SSI0RX | UDMA_PRI_SELECT);
ActivePage = 0;
uDMAChannelTransferSet(UDMA_CHANNEL_SSI0RX | UDMA_PRI_SELECT,
DMASecondary_Buffer, SSI_RXBUF_SIZE);
// Initializes the SSI0 transfer
void
InitSSI0Transfer(void)
uint8_t ui8Idx = 0;
GPIO_toggle(Board_LED0);
// Fill the TX buffer with a simple data pattern.
for(ui8Idx = 0; ui8Idx < SSI_TXBUF_SIZE; ui8Idx++)
DMATxBuffer[ui8Idx] = ui8Idx+1;
// Configure the SSI communication parameters.
SSIConfigSetExpClk(SSI0_BASE, 120000000 /* SysCtlClockGet() */, SSI_FRF_MOTO_MODE_0,
SSI_MODE_MASTER, 4000000, 16);
// Enable the SSI for operation, and enable the uDMA interface for both TX
// and RX channels.
SSIEnable(SSI0_BASE);
SSIDMAEnable(SSI0_BASE, SSI_DMA_TX | SSI_DMA_RX );
// Enable the uDMA controller error interrupt. This interrupt will occur
// if there is a bus error during a transfer.
IntEnable(INT_UDMAERR);
// Enable the SSI peripheral, and configure it to operate even if the CPU
// is in sleep.
SysCtlPeripheralEnable(SYSCTL_PERIPH_UDMA);
SysCtlPeripheralSleepEnable(SYSCTL_PERIPH_UDMA);
// Enable the uDMA controller.
uDMAEnable();
// Point at the control table to use for channel control structures.
uDMAControlBaseSet(pui8ControlTable);
SysCtlPeripheralEnable(SYSCTL_PERIPH_SSI0);
SysCtlPeripheralSleepEnable(SYSCTL_PERIPH_SSI0);
// Put the attributes in a known state for the uDMA SSI1RX channel. These
// should already be disabled by default.
uDMAChannelAttributeDisable(UDMA_CHANNEL_SSI0RX, UDMA_ATTR_USEBURST | UDMA_ATTR_REQMASK );
uDMAChannelAttributeDisable(UDMA_CHANNEL_SSI0RX, UDMA_ATTR_ALTSELECT | UDMA_ATTR_USEBURST | UDMA_ATTR_REQMASK );
// Configure the control parameters for the primary control structure for
// the SSI RX channel. The primary contol structure is used for the "A"
// part of the ping-pong receive. The transfer data size is 8 bits, the
// source address does not increment since it will be reading from a
// register. The destination address increment is byte 8-bit bytes. The
// arbitration size is set to 4 to match the RX FIFO trigger threshold.
// The uDMA controller will use a 4 byte burst transfer if possible. This
// will be somewhat more effecient that single byte transfers.
uDMAChannelControlSet(UDMA_CHANNEL_SSI0RX | UDMA_PRI_SELECT,
UDMA_SIZE_8 | UDMA_SRC_INC_NONE | UDMA_DST_INC_8 |
UDMA_ARB_4);
// Set up the transfer parameters for the SSI RX primary control
// structure. The mode is set to ping-pong, the transfer source is the
// SSI data register, and the destination is the receive "A" buffer. The
// transfer size is set to match the size of the buffer.
UDMA_MODE_PINGPONG,
DMAPrimary_Buffer, sizeof(DMAPrimary_Buffer));
// Configure the control parameters for the alternate control structure for
// the SSI RX channel. The alternate contol structure is used for the "B"
// part of the ping-pong receive. The configuration is identical to the
// primary/A control structure.
uDMAChannelControlSet(UDMA_CHANNEL_SSI0RX | UDMA_ALT_SELECT,
UDMA_ARB_4);
// Set up the transfer parameters for the SSI RX alternate control
// SSI data register, and the destination is the receive "B" buffer. The
UDMA_MODE_PINGPONG,
DMASecondary_Buffer, sizeof(DMASecondary_Buffer));
uDMAChannelAttributeDisable(UDMA_CHANNEL_SSI0TX,
UDMA_ATTR_HIGH_PRIORITY |
UDMA_ATTR_REQMASK);
// Set the USEBURST attribute for the uDMA SSI TX channel. This will
// force the controller to always use a burst when transferring data from
// the TX buffer to the SSI. This is somewhat more effecient bus usage
// than the default which allows single or burst transfers.
//uDMAChannelAttributeEnable(UDMA_CHANNEL_SSI0TX, UDMA_ATTR_USEBURST);
uDMAChannelAttributeEnable(UDMA_CHANNEL_SSI0TX, UDMA_ATTR_HIGH_PRIORITY);
// Configure the control parameters for the SSI TX. The uDMA SSI TX
// channel is used to transfer a block of data from a buffer to the SSI.
// The data size is 8 bits. The source address increment is 8-bit bytes
// since the data is coming from a buffer. The destination increment is
// none since the data is to be written to the SSI data register. The
// arbitration size is set to 4, which matches the SSI TX FIFO trigger
// threshold.
uDMAChannelControlSet(UDMA_CHANNEL_SSI0TX | UDMA_PRI_SELECT,
UDMA_SIZE_8 | UDMA_SRC_INC_8 |
UDMA_DST_INC_NONE |
UDMA_ARB_4);
// Set up the transfer parameters for the uDMA SSI TX channel. This will
// configure the transfer source and destination and the transfer size.
// Basic mode is used because the peripheral is making the uDMA transfer
// request. The source is the TX buffer and the destination is the SSI
// data register.
uDMAChannelTransferSet(UDMA_CHANNEL_SSI0TX | UDMA_PRI_SELECT,
UDMA_MODE_BASIC, DMATxBuffer,
sizeof(DMATxBuffer));
// Now both the uDMA SSI TX and RX channels are primed to start a
// transfer. As soon as the channels are enabled, the peripheral will
// issue a transfer request and the data transfers will begin.
uDMAChannelEnable(UDMA_CHANNEL_SSI0TX);
// Enable the SSI DMA TX/RX interrupts.
SSIIntEnable(SSI0_BASE, SSI_RXFF);
// Enable the SSI peripheral interrupts.
IntEnable(INT_SSI0);
ui32Status = SSIIntStatus(SSI0_BASE, FALSE);
System_printf("value 0x%x\n", ui32Status);
System_flush();
Void heartBeatFxn(UArg arg0, UArg arg1)
uint8_t i=0;
InitSSI0Transfer();
while (1) {
//Task_sleep((unsigned int)arg0);
for(i=0;i<8;i++)
System_printf("values are 0x%x\n", DMAPrimary_Buffer[i]);
System_flush();
* ======== main ========
int main(void)
Task_Params taskParams;
/* Call board init functions */
Board_initGeneral();
// Board_initEMAC();
Board_initGPIO();
// Board_initI2C();
// Board_initSDSPI();
Board_initSPI();
//Board_initSSI();
// Board_initUSB(Board_USBDEVICE);
// Board_initUSBMSCHFatFs();
// Board_initWatchdog();
// Board_initWiFi();
/* Construct heartBeat Task thread */
Task_Params_init(&taskParams);
taskParams.arg0 = 1000;
taskParams.stackSize = TASKSTACKSIZE;
taskParams.stack = &task0Stack;
Task_construct(&task0Struct, (Task_FuncPtr)heartBeatFxn, &taskParams, NULL);
System_printf("Starting the example\nSystem provider is set to SysMin. "
"Halt the target to view any SysMin contents in ROV.\n");
/* SysMin will only print to the console when you call flush or exit */
System_flush();
/* Start BIOS */
BIOS_start();
return (0);
// startup_ccs.c - Startup code for use with TI's Code Composer Studio.
// Copyright (c) 2013-2017 Texas Instruments Incorporated. All rights reserved.
// Software License Agreement
// Texas Instruments (TI) is supplying this software for use solely and
// exclusively on TI's microcontroller products. The software is owned by
// TI and/or its suppliers, and is protected under applicable copyright
// laws. You may not combine this software with "viral" open-source
// software in order to form a larger program.
// THIS SOFTWARE IS PROVIDED "AS IS" AND WITH ALL FAULTS.
// NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT
// NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. TI SHALL NOT, UNDER ANY
// CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR CONSEQUENTIAL
// DAMAGES, FOR ANY REASON WHATSOEVER.
// This is part of revision 2.1.4.178 of the EK-TM4C1294XL Firmware Package.
#include <stdint.h>
#include "inc/hw_nvic.h"
#include "inc/hw_types.h"
// Forward declaration of the default fault handlers.
void ResetISR(void);
static void NmiSR(void);
static void FaultISR(void);
static void IntDefaultHandler(void);
// External declaration for the reset handler that is to be called when the
// processor is started
extern void _c_int00(void);
// Linker variable that marks the top of the stack.
extern uint32_t __STACK_TOP;
// External declarations for the interrupt handlers used by the application.
extern void SysTickHandler(void);
extern void SSI0IntHandler(void);
extern void uDMAIntHandler(void);
extern void uDMAErrorHandler(void);
// The vector table. Note that the proper constructs must be placed on this to
// ensure that it ends up at physical address 0x0000.0000 or at the start of
// the program if located at a start address other than 0.
#pragma DATA_SECTION(g_pfnVectors, ".intvecs")
void (* const g_pfnVectors[])(void) =
(void (*)(void))((uint32_t)&__STACK_TOP),
// The initial stack pointer
ResetISR, // The reset handler
NmiSR, // The NMI handler
FaultISR, // The hard fault handler
IntDefaultHandler, // The MPU fault handler
IntDefaultHandler, // The bus fault handler
IntDefaultHandler, // The usage fault handler
0, // Reserved
0, // Reserved
0, // Reserved
0, // Reserved
IntDefaultHandler, // SVCall handler
IntDefaultHandler, // Debug monitor handler
0, // Reserved
IntDefaultHandler, // The PendSV handler
SysTickHandler, // The SysTick handler
IntDefaultHandler, // GPIO Port A
IntDefaultHandler, // GPIO Port B
IntDefaultHandler, // GPIO Port C
IntDefaultHandler, // GPIO Port D
IntDefaultHandler, // GPIO Port E
IntDefaultHandler, // UART0 Rx and Tx
IntDefaultHandler, // UART1 Rx and Tx
SSI0IntHandler, // SSI0 Rx and Tx
IntDefaultHandler, // I2C0 Master and Slave
IntDefaultHandler, // PWM Fault
IntDefaultHandler, // PWM Generator 0
IntDefaultHandler, // PWM Generator 1
IntDefaultHandler, // PWM Generator 2
IntDefaultHandler, // Quadrature Encoder 0
IntDefaultHandler, // ADC Sequence 0
IntDefaultHandler, // ADC Sequence 1
IntDefaultHandler, // ADC Sequence 2
IntDefaultHandler, // ADC Sequence 3
IntDefaultHandler, // Watchdog timer
IntDefaultHandler, // Timer 0 subtimer A
IntDefaultHandler, // Timer 0 subtimer B
IntDefaultHandler, // Timer 1 subtimer A
IntDefaultHandler, // Timer 1 subtimer B
IntDefaultHandler, // Timer 2 subtimer A
IntDefaultHandler, // Timer 2 subtimer B
IntDefaultHandler, // Analog Comparator 0
IntDefaultHandler, // Analog Comparator 1
IntDefaultHandler, // Analog Comparator 2
IntDefaultHandler, // System Control (PLL, OSC, BO)
IntDefaultHandler, // FLASH Control
IntDefaultHandler, // GPIO Port F
IntDefaultHandler, // GPIO Port G
IntDefaultHandler, // GPIO Port H
IntDefaultHandler, // UART2 Rx and Tx
IntDefaultHandler, // SSI1 Rx and Tx
IntDefaultHandler, // Timer 3 subtimer A
IntDefaultHandler, // Timer 3 subtimer B
IntDefaultHandler, // I2C1 Master and Slave
IntDefaultHandler, // CAN0
IntDefaultHandler, // CAN1
IntDefaultHandler, // Ethernet
IntDefaultHandler, // Hibernate
IntDefaultHandler, // USB0
IntDefaultHandler, // PWM Generator 3
uDMAIntHandler, // uDMA Software Transfer
uDMAErrorHandler, // uDMA Error
IntDefaultHandler, // ADC1 Sequence 0
IntDefaultHandler, // ADC1 Sequence 1
IntDefaultHandler, // ADC1 Sequence 2
IntDefaultHandler, // ADC1 Sequence 3
IntDefaultHandler, // External Bus Interface 0
IntDefaultHandler, // GPIO Port J
IntDefaultHandler, // GPIO Port K
IntDefaultHandler, // GPIO Port L
IntDefaultHandler, // SSI2 Rx and Tx
IntDefaultHandler, // SSI3 Rx and Tx
IntDefaultHandler, // UART3 Rx and Tx
IntDefaultHandler, // UART4 Rx and Tx
IntDefaultHandler, // UART5 Rx and Tx
IntDefaultHandler, // UART6 Rx and Tx
IntDefaultHandler, // UART7 Rx and Tx
IntDefaultHandler, // I2C2 Master and Slave
IntDefaultHandler, // I2C3 Master and Slave
IntDefaultHandler, // Timer 4 subtimer A
IntDefaultHandler, // Timer 4 subtimer B
IntDefaultHandler, // Timer 5 subtimer A
IntDefaultHandler, // Timer 5 subtimer B
IntDefaultHandler, // FPU
0, // Reserved
0, // Reserved
IntDefaultHandler, // I2C4 Master and Slave
IntDefaultHandler, // I2C5 Master and Slave
IntDefaultHandler, // GPIO Port M
IntDefaultHandler, // GPIO Port N
0, // Reserved
IntDefaultHandler, // Tamper
IntDefaultHandler, // GPIO Port P (Summary or P0)
IntDefaultHandler, // GPIO Port P1
IntDefaultHandler, // GPIO Port P2
IntDefaultHandler, // GPIO Port P3
IntDefaultHandler, // GPIO Port P4
IntDefaultHandler, // GPIO Port P5
IntDefaultHandler, // GPIO Port P6
IntDefaultHandler, // GPIO Port P7
IntDefaultHandler, // GPIO Port Q (Summary or Q0)
IntDefaultHandler, // GPIO Port Q1
IntDefaultHandler, // GPIO Port Q2
IntDefaultHandler, // GPIO Port Q3
IntDefaultHandler, // GPIO Port Q4
IntDefaultHandler, // GPIO Port Q5
IntDefaultHandler, // GPIO Port Q6
IntDefaultHandler, // GPIO Port Q7
IntDefaultHandler, // GPIO Port R
IntDefaultHandler, // GPIO Port S
IntDefaultHandler, // SHA/MD5 0
IntDefaultHandler, // AES 0
IntDefaultHandler, // DES3DES 0
IntDefaultHandler, // LCD Controller 0
IntDefaultHandler, // Timer 6 subtimer A
IntDefaultHandler, // Timer 6 subtimer B
IntDefaultHandler, // Timer 7 subtimer A
IntDefaultHandler, // Timer 7 subtimer B
IntDefaultHandler, // I2C6 Master and Slave
IntDefaultHandler, // I2C7 Master and Slave
IntDefaultHandler, // HIM Scan Matrix Keyboard 0
IntDefaultHandler, // One Wire 0
IntDefaultHandler, // HIM PS/2 0
IntDefaultHandler, // HIM LED Sequencer 0
IntDefaultHandler, // HIM Consumer IR 0
IntDefaultHandler, // I2C8 Master and Slave
IntDefaultHandler, // I2C9 Master and Slave
IntDefaultHandler // GPIO Port T
// This is the code that gets called when the processor first starts execution
// following a reset event. Only the absolutely necessary set is performed,
// after which the application supplied entry() routine is called. Any fancy
// actions (such as making decisions based on the reset cause register, and
// resetting the bits in that register) are left solely in the hands of the
// application.
void
ResetISR(void)
// Jump to the CCS C initialization routine. This will enable the
// floating-point unit as well, so that does not need to be done here.
__asm(" .global _c_int00\n"
" b.w _c_int00");
// This is the code that gets called when the processor receives a NMI. This
// simply enters an infinite loop, preserving the system state for examination
// by a debugger.
static void
NmiSR(void)
// Enter an infinite loop.
while(1)
// This is the code that gets called when the processor receives a fault
// interrupt. This simply enters an infinite loop, preserving the system state
// for examination by a debugger.
static void
FaultISR(void)
while(1)
// This is the code that gets called when the processor receives an unexpected
static void
// Go into an infinite loop.
while(1)
Manohar
