EK-TM4C1294XL: CMSIS DSP Library for TM4C129
Part Number: EK-TM4C1294XL
Hello All,
I'am trying to use CMSIS DSP Library with TM4C1294XL Launchpad. I'am implementing the low pass filter of the library using arm_fir_f32 function.
In the Fir example for the library it is written
* Note that the filter is symmetric (a property of linear phase FIR filters)
* and the point of symmetry is sample 14. Thus the filter will have a delay of
* 14 samples for all frequencies.
That means the filter will have a delay of (N-1) samples i.e. (NUM_TAPS -1)/2 in its output
Now this property does not gives a real time continuous  filter output signal which can be plotted further.
How to remove this delay in the output signal?
kindly suggest a solution for the problem
  • Design a circuit to sample the future waveform instead. Or perhaps simpler, don't use a symmetric FIR.
    A general DSP guide that contains a reasonable discussion of filters.
    www.analog.com/.../scientist_engineers_guide.html
    Robert
  • *** LIKE ***
    To your "well thought TAG" (it also warrants a "LIKE") - the clause, "become a skilled tech investigator" may deserve consideration.
    Regarding the "TAG" entry - is not vendor's: "Forced, MCU IDs inclusion" - too often an "ILL CONSIDERED" LIMITATION!    Robert's advice here, "Is surely NOT bound to any SINGLE vendor MCU" - thus forcing the post's Tag to MCU_X (may) preclude this valuable posting from being found by those employing a "different, vendor supplied, MCU!"    Had that fact been noted - even considered?    (appears similar to the most unfortunate, highly troubling: "Banning of LIKE" - justified via grade-school logic!      (a slow grade school - at that!)
    Most always more appropriate - "broad based investigations" provide:
    • added detail
    • competing viewpoints
    • limitations of the approach (possible suggestions of "other" methods")   [illustrated by you - right here - "Don't use a symmetric FIR!"]
    Poster "has" made good effort - yet "broadening his investigatory base" (far beyond this MCU forum) will prove his best "roadmap to success!"   (R.A. may not (always) be at "beck & call!")
