TM4C129EKCPDT: How to jump to application address from bootloader
Part Number: TM4C129EKCPDT
Hi
I put bootloader in flash 0x0~0x10000, application in  0x10000~0x7FFFF.
Could you let me know how to jump to 0x10000 after finish downloading the firmware? Is there a jump example?
I write below code but it doesn't jump to the application address. Thanks.
#define ApplicationAddress   0x10000
void Jump2App(void)
         // turn off SysTick and its interrupt before entering
         ROM_SysTickIntDisable();
         ROM_SysTickDisable();
         // Disable all processor interrupts.
         HWREG(NVIC_DIS0) = 0xffffffff;
         HWREG(NVIC_DIS1) = 0xffffffff;
         HWREG(NVIC_DIS2) = 0xffffffff;
         HWREG(NVIC_DIS3) = 0xffffffff;
         HWREG(NVIC_DIS4) = 0xffffffff;
         (*((void (*)(void))(*(uint32_t *)ApplicationAddress)))();
  • Hi Daniel,
      Have you tried out the various bootloader examples that come with the TivaWare library? Please check out the bl_startup_ccs.s startup file in the bootloader example. Below is a snippet of the code.
        ;; Load the stack pointer from the application's vector table.
     .if (APP_START_ADDRESS != VTABLE_START_ADDRESS)
        movw    r0, #(APP_START_ADDRESS & 0xffff)
     .if (APP_START_ADDRESS > 0xffff)
        movt    r0, #(APP_START_ADDRESS >> 16)
     .endif
     .endif
        ldr     sp, [r0]
        ;; Load the initial PC from the application's vector table and branch to
        ;; the application's entry point.
        ldr     r0, [r0, #4]
        bx      r0
        .endasmfunc
