Part Number: TM4C123GH6PM
Other Parts Discussed in Thread: EK-TM4C123GXL
I was trying to use the UART printf function, but I receive unresolved symbol errors.
For back ground reference, I am working on Tiva-C workshop lab 12 starting on step 20 (https://engineering.purdue.edu/ece477/Archive/2014/Spring/S14-Grp1/docs/software/LM4F-LaunchPad-12%20-%20UART.pdf).
This my current software versions:
- CCS v6.2.0.00050
- Compiler Version: TI v15.12.6.LTS
- TivaC Version: 2.16.1.14
- XDCtools version: 3.32.1.22_core
After reading the documentation in uartstdio.c, I've discovered that calling UARTStdioConfig() is how I can enable UART and be able to use UARTprintf(). My code already has this config called so now I'm left with one unsolved symbol: "__error__".
my main.c file: /cfs-file/__key/communityserver-discussions-components-files/81/8420.main.c
**** Build of configuration Debug for project lab12_part2 ****
"C:\\ti\\ccsv6\\utils\\bin\\gmake" -k all
'Building file: ../main.c'
'Invoking: ARM Compiler'
"C:/ti/ccsv6/tools/compiler/ti-cgt-arm_15.12.6.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_15.12.6.LTS/include" --include_path="C:/ti/tirtos_tivac_2_16_01_14/products/TivaWare_C_Series-2.1.1.71b" --include_path="C:/ti/tirtos_tivac_2_16_01_14/products/TivaWare_C_Series-2.1.1.71b/utils" -g --gcc --define=DEBUG --define=PART_TM4C123GH6PM--define=TARGET_IS_BLIZZARD_RB1 --define=ccs="ccs" --display_error_number --diag_wrap=off --diag_warning=225 --abi=eabi --preproc_with_compile --preproc_dependency="main.d" "../main.c"
'Finished building: ../main.c'
'Building target: lab12_part2.out'
'Invoking: ARM Linker'
"C:/ti/ccsv6/tools/compiler/ti-cgt-arm_15.12.6.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -g --gcc --define=DEBUG --define=PART_TM4C123GH6PM --define=TARGET_IS_BLIZZARD_RB1 --define=ccs="ccs" --display_error_number --diag_wrap=off --diag_warning=225 --abi=eabi -z -m"lab12_part2.map" --heap_size=0 --stack_size=100 -i"C:/ti/ccsv6/tools/compiler/ti-cgt-arm_15.12.6.LTS/lib" -i"C:/ti/tirtos_tivac_2_16_01_14/products/TivaWare_C_Series-2.1.1.71b/utils" -i"C:/ti/ccsv6/tools/compiler/ti-cgt-arm_15.12.6.LTS/include" --reread_libs --warn_sections --display_error_number --diag_wrap=off --xml_link_info="lab12_part2_linkInfo.xml" --rom_model -o "lab12_part2.out" "./main.obj" "./tm4c123gh6pm_startup_ccs.obj" "./uartstdio.obj" "C:/ti/tirtos_tivac_2_16_01_14/products/TivaWare_C_Series-2.1.1.71b/driverlib/ccs/Debug/driverlib.lib" "../tm4c123gh6pm.cmd" -llibc.a
<Linking>
undefined first referenced
symbol in file
__error__ ./uartstdio.obj
error #10234-D: unresolved symbols remain
error #10010: errors encountered during linking; "lab12_part2.out" not built
>> Compilation failure
makefile:143: recipe for target 'lab12_part2.out' failed
gmake: *** [lab12_part2.out] Error 1
gmake: Target 'all' not remade because of errors.
**** Build Finished ****
