Part Number: RM57L843
I intend to use asynchronous 256MB Flash with RM57L on EMIF. The address lines required is not available in the package. However, it has been mentioned in the datasheet that GPIO can be used to integrate higher flash capacity.
Can you please share any application note explaining which I/O and how it can be done?
Also how the address space will be mapped on the memory map of a device as available EMIF space is not enough unless we use reserved pins?
Will the DMA mode be available to work in the same settings if we use higher flash capacity?
Thank you.
Regards;
