Part Number: TM4C1292NCPDT
Tool/software: TI-RTOS
I have to download a file of size 200kb using TFTP protocol and store the file to flash memory at address 0x00084000. The file download is done and to store the file to the specified address in flash I modified the
tftpProcessPacket() in tftp.c , as in the attached file. I have changed the flash start address of the file to be downloaded to 0x00084000 in cmd file.
While programming to flash, do I need to program the whole file at once? Can I program to flash as each packet is received?
Is the way I have done right?
Please guide me to properly download the file to the flash at address 0x00084000.
TI RTOS version is 2.16.01.14.
The NDK version is 2.25.00.09.
* Copyright (c) 2012, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* ======== tftp.c ========
* TFTP
#include "tftpinc.h"
#include "socketndk.h"
#include <stdio.h>
#include "flash.h"
#include "inc/hw_flash.h"
static int tftpGetFile( TFTP *pTftp);
static int tftpSocketSetup( TFTP *pTftp );
static void tftpRRQBuild(TFTP *pTftp);
static void tftpACKBuild(TFTP *pTftp);
static void tftpFlushPackets(TFTP *pTftp);
static int tftpReadPacket( TFTP *pTftp );
static int tftpProcessPacket( TFTP *pTftp );
static int tftpSend( TFTP *pTftp);
#define APP_START_ADDRESS 0x084000;
#define FLASH_PAGE_SIZE 0x00000400
uint32_t ui32FlashAddr;
* tftpSocketSetup()
* Setup initial socket for TFTP transfer
int rc; /* Return Code */
struct timeval timeout;
/* Create UDP socket */
pTftp->Sock = socket(AF_INET, SOCK_DGRAM, IPPROTO_UDP);
if( pTftp->Sock == INVALID_SOCKET )
rc = TFTPERROR_SOCKET;
goto ABORT;
/* Initialize the bind the local address */
bzero( &pTftp->tmpaddr, sizeof(struct sockaddr_in) );
pTftp->tmpaddr.sin_family = AF_INET;
/* Assign local name to the unnamed socket */
/* Do not care about local Host Address or Port (both 0) */
/* If no error, bind returns 0 */
if( bind( pTftp->Sock, (PSA)&pTftp->tmpaddr, sizeof(pTftp->tmpaddr) ) < 0 )
goto ABORT;
/* Set the socket IO timeout */
timeout.tv_sec = TFTP_SOCK_TIMEOUT;
timeout.tv_usec = 0;
if( setsockopt( pTftp->Sock, SOL_SOCKET, SO_SNDTIMEO,
&timeout, sizeof(timeout)) < 0 )
goto ABORT;
if( setsockopt( pTftp->Sock, SOL_SOCKET, SO_RCVTIMEO,
goto ABORT;
/* Initialize the foreign address - we don't use "connect", since */
/* the peer port will change. We use sendto() */
bzero( &pTftp->peeraddr, sizeof(struct sockaddr_in) );
pTftp->peeraddr.sin_family = AF_INET;
pTftp->peeraddr.sin_addr.s_addr = pTftp->PeerAddress; // todo
pTftp->peeraddr.sin_port = htons(PORT_TFTP);
rc = 0;
ABORT:
return(rc);
* tftpRRQBuild()
* Build an initial file request packet
struct tftphdr *RRQ_Packet;
static char *pszOctet = "octet";
char *pRRQ_Data;
RRQ_Packet = (struct tftphdr *)pTftp->PacketBuffer;
/* A request packet consists of an opcode (RRQ) followed */
/* by a NULL terminated filename and mode ("octet") */
/* Opcode = RRQ */
RRQ_Packet->opcode = htons(RRQ);
/* Get a pointer to the rest of the packet */
pRRQ_Data = (char *)&RRQ_Packet->block;
/* Copy NULL terminated filename string to request */
/* increment data pointer by length of Filename (and terminating '0') */
strcpy(pRRQ_Data, pTftp->szFileName);
pRRQ_Data += strlen(pTftp->szFileName) + 1;
/* Copy NULL terminated mode string to request */
/* increment data pointer by length of mode (and terminating '0') */
strcpy(pRRQ_Data, pszOctet);
pRRQ_Data += strlen(pszOctet) + 1;
/* calculate length of packet */
pTftp->Length = (int)(pRRQ_Data - (char *)RRQ_Packet);
return;
* tftpACKBuild()
* Bluild TFTP block ACK packet
struct tftphdr *ACK_Packet;
ACK_Packet = (struct tftphdr *)pTftp->PacketBuffer;
ACK_Packet->opcode = htons(ACK);
/* Build the rest of the ACK packet */
/* Block Number */
ACK_Packet->block = htons( pTftp->NextBlock );
/* Set length of packet */
pTftp->Length = 4; /* Opcode + Block */
* tftpSend()
* Send pre-built packet to peer
int rc = 0;
int BytesSent;
// printf("pTftp->Sock=%d\n",pTftp->Sock);
// printf(" pTftp->PacketBuffer=%x\n", pTftp->PacketBuffer);
// printf("pTftp->Length=%d\n",pTftp->Length);
BytesSent = sendto(pTftp->Sock, pTftp->PacketBuffer,
(int)pTftp->Length, 0,(struct sockaddr *)&pTftp->peeraddr,
sizeof(pTftp->peeraddr));
if ( BytesSent != (int)pTftp->Length )
return(rc);
* tftpReadPacket()
* Read a data packet from the peer socket
* Sets bytes read to ZERO on a timeout
int rc = 0;
int addrLength;
struct tftphdr *ReadBuffer;
INT32 BytesRead;
UINT32 TimeStart;
ReadBuffer = (struct tftphdr *)pTftp->PacketBuffer;
TimeStart = llTimerGetTime(0);
RETRY:
/* Don't allow stray traffic to keep us alive */
if( (TimeStart+TFTP_SOCK_TIMEOUT) <= llTimerGetTime(0) )
BytesRead = 0;
goto ABORT;
/* Attempt to read data */
addrLength = sizeof(pTftp->tmpaddr);
BytesRead = recvfrom( pTftp->Sock, ReadBuffer, DATA_SIZE, 0,
(struct sockaddr *)&pTftp->tmpaddr, &addrLength );
/* Handle read errors first */
if( BytesRead < 0 )
/* On a timeout error, ABORT with no error */
/* Else report error */
if( fdError() == EWOULDBLOCK )
BytesRead = 0;
else
goto ABORT;
/* If this packet is not from our peer, retry */
if( pTftp->tmpaddr.sin_addr.s_addr != pTftp->PeerAddress )
goto RETRY;
/* If the peer port is NOT TFTP, then it must match our expected */
/* peer. */
if( pTftp->peeraddr.sin_port != htons(PORT_TFTP) )
if( pTftp->tmpaddr.sin_port != pTftp->peeraddr.sin_port )
goto RETRY;
ABORT:
pTftp->Length = (UINT32)BytesRead; /* Store number of bytes read */
return(rc);
* tftpFlushPackets()
* Flush all input from socket
int bytesread;
/* Sleep for a second */
TaskSleep( 1000 );
do
bytesread = recv( pTftp->Sock, pTftp->PacketBuffer,
DATA_SIZE, MSG_DONTWAIT );
} while( bytesread > 0 );
* tftpReSync()
* Attempt to ReSync a failed transfer
int tftpReSync( TFTP *pTftp )
int rc = 0;
/* Fluch pending input packets */
tftpFlushPackets( pTftp );
/* Abort if too many Sync errors */
pTftp->MaxSyncError--;
if( pTftp->MaxSyncError == 0 )
rc = TFTPERROR_FAILED;
goto ABORT; /* Too Many Sync Errors */
/* Back up expected block */
pTftp->NextBlock--;
/* Resend last packet - if we're on block ZERO, resend the initial */
/* request. */
if( !pTftp->NextBlock )
tftpRRQBuild( pTftp );
else
tftpACKBuild( pTftp );
/* Send the packet */
rc = tftpSend( pTftp );
if( rc < 0 )
goto ABORT;
pTftp->NextBlock++; /* Increment next expected BLOCK */
ABORT:
return(rc);
* tftpProcessPacket()
* Processes a data packet obtained from ReadPacket()
* Returns:
* 1 - Operation Complete
* 0 - Operation Progressing
* <0 - Error Condition
int rc = 0, done = 0;
UINT16 OpCode;
UINT16 ServerBlock;
UINT32 CopySize;
uint32_t n;
/* Check for a bad packet - resynch on error */
if( !pTftp->Length )
return( tftpReSync( pTftp ) );
OpCode = (UINT16) ntohs(ReadBuffer->opcode);
switch (OpCode)
case ERROR :
/* Copy the error code */
pTftp->ErrorCode = (UINT16) ntohs(ReadBuffer->block);
/* If the buffer is large enough, copy the error message */
pTftp->Length -= TFTP_HEADER; /* Get payload length */
/* Copy file data if room left in buffer is large enough */
if( pTftp->BufferSize >= pTftp->Length )
bcopy( ReadBuffer->data, pTftp->Buffer, (int)pTftp->Length );
pTftp->BufferUsed = pTftp->Length;
else
pTftp->BufferUsed = 0;
rc = TFTPERROR_ERRORREPLY;
break;
case DATA :
/* Received Data, verify BLOCK correct */
ServerBlock = (UINT16) ntohs(ReadBuffer->block);
/* If this is not the block we're expecting, resync */
if (pTftp->NextBlock != ServerBlock)
rc = tftpReSync( pTftp );
pTftp->Length = 0;
break;
/* If this is the first block, reset our port number. */
if( pTftp->NextBlock == 1 )
pTftp->peeraddr.sin_port = pTftp->tmpaddr.sin_port; /* Update TID */
/* Block is for me! */
pTftp->MaxSyncError = MAX_SYNC_TRIES; /* reset Sync Counter */
CopySize = pTftp->Length; /* Copy length */
pTftp->FileSize += CopySize; /* Track the file length */
if( pTftp->BufferSize > pTftp->BufferUsed )
if( (pTftp->BufferSize - pTftp->BufferUsed) < CopySize)
CopySize = pTftp->BufferSize - pTftp->BufferUsed;
if( CopySize )
/* Add it to our receive buffer */
bcopy( ReadBuffer->data, (pTftp->Buffer+pTftp->BufferUsed),
(int)CopySize );
/* Track the number of bytes used */
pTftp->BufferUsed += CopySize;
else
ui32FlashAddr =
((pTftp->NextBlock - 1) * SEGSIZE) + APP_START_ADDRESS;
FlashProtectSet((uint32_t) ui32FlashAddr,FlashReadWrite);
FlashProtectSave();
// FlashErase((uint32_t ) ui32FlashAddr);
printf("pTftp->BufferUsed=%d\n",pTftp->BufferUsed);
n = FlashProgram(ReadBuffer->data,
(uint32_t )ui32FlashAddr, CopySize);
printf("n=%d\n",n);
/* If we received a partial block, we're done */
if( pTftp->Length < SEGSIZE )
done = 1;
/* Need to acknowledge this block */
if( rc < 0 )
break;
pTftp->NextBlock++;
/* Our done flag is the return code on success */
rc = done;
break;
default:
break;
return(rc);
/* tftpGetFile() */
/* Called to receive a file using TFTP. Called with TFTP parameter */
/* structure initialized. */
/* Returns: */
/* 1 - If file was sucessfully transferred */
/* 0 - If the file was transferred but too large for the buffer */
/* <0 - Error */
static int tftpGetFile( TFTP *pTftp )
int rc = 0;
/* Build the request packet */
/* Send the request packet */
if( rc < 0 )
goto ABORT;
/* Now look for response packets */
pTftp->MaxSyncError = MAX_SYNC_TRIES; /* set sync error counter */
pTftp->NextBlock = 1; /* first block expected is "1" */
for(;;)
/* Try and get a reply packet */
rc = tftpReadPacket( pTftp );
if( rc < 0 )
goto ABORT;
/* Process the reply packet */
rc = tftpProcessPacket( pTftp );
if( rc < 0 )
goto ABORT;
/* If done, break out of loop */
if( rc == 1 )
break;
/* If the receive buffer was too small, return 0, else return 1 */
if( pTftp->BufferUsed < pTftp->FileSize )
rc = 0;
else
rc = 1;
ABORT:
return(rc);
/* int NtTftpRecv() */
/* Retrieve a file using TFTP */
/* Return Conditions: */
/* In the following cases, FileSize is set to the actual file size: */
/* In the following cases, FileSize is set to the actual number of */
/* bytes copied. */
/* <0 - Error */
/* TFTPERROR_ERRORCODE: TFTP server error code. The error code */
/* is written to pErrorCode, and an error message is */
/* written to FileBuffer. The length of the error message */
/* is written to FileSize. */
int NtTftpRecv( UINT32 TftpIP, char *szFileName, char *FileBuffer,
UINT32 *FileSize, UINT16 *pErrorCode )
TFTP *pTftp;
printf("TftpIP= %lu\n",TftpIP);
/* Quick parameter validation */
if( !szFileName || !FileSize || (*FileSize != 0 && !FileBuffer) )
return( TFTPERROR_BADPARAM );
/* Malloc Parameter Structure */
if( !(pTftp = mmAlloc( sizeof(TFTP) )) )
return( TFTPERROR_RESOURCES );
/* Initialize parameters to "NULL" */
bzero( pTftp, sizeof(TFTP) );
pTftp->Sock = INVALID_SOCKET;
/* Malloc Packet Data Buffer */
if( !(pTftp->PacketBuffer = mmAlloc( DATA_SIZE )) )
rc = TFTPERROR_RESOURCES;
goto ABORT;
/* store IP in network byte order */
pTftp->PeerAddress =TftpIP;
/* Setup initial socket */
rc = tftpSocketSetup( pTftp );
if( rc < 0 )
goto ABORT;
/* Socket now registered and available for use. Get the data */
pTftp->szFileName = szFileName;
pTftp->Buffer = FileBuffer;
pTftp->BufferSize = *FileSize; /* Do not read more than can fit in file */
/* Get the requested file */
rc = tftpGetFile( pTftp );
if( rc < 0 )
/* ERROR CONDITION */
/* Set the "FileSize" to the actual number of bytes copied */
*FileSize = pTftp->BufferUsed;
/* If the ErrorCode pointer is valid, copy it */
if( pErrorCode )
*pErrorCode = pTftp->ErrorCode;
else
/* SUCCESS CONDITION */
/* Set the "FileSize" to the file size (regardless of bytes copied) */
*FileSize = pTftp->FileSize;
ABORT:
if( pTftp->Sock != INVALID_SOCKET )
fdClose( pTftp->Sock );
if( pTftp->PacketBuffer )
mmFree( pTftp->PacketBuffer );
mmFree( pTftp );
return(rc);
Sandra
