TM4C1294NCPDT: TM4C_PINMUX is not available on TI website
Part Number: TM4C1294NCPDT
Hi Champs,
I checked TM4C_PINMUX on TI website, I can't find download icon to download this tool. Could you please tell me where I can get TM4C_PINMUX ? thanks
  • Hello Lisa,
    The PINMUX utility can be found at https://dev.ti.com/pinmux
  • Hi Ralph,
    Customer used Tiva C series PinMux and generate code. Also he used PinMux tool you mentioned to generate code also. However, he found there is a difference. Please see below code. Now we recommend customer to use Pinmux instead of  Tiva C Series PinMux . Am i right ? thanks.
    // Enable pin PD7 for USB0 USB0PFLT
    // First open the lock and select the bits we want to modify in the GPIO commit register.
    HWREG(GPIO_PORTD_BASE + GPIO_O_LOCK) = GPIO_LOCK_KEY;
    HWREG(GPIO_PORTD_BASE + GPIO_O_CR) = 0x80;
    // Now modify the configuration of the pins that we unlocked.
    MAP_GPIOPinConfigure(GPIO_PD7_USB0PFLT);
    MAP_GPIOPinTypeUSBDigital(GPIO_PORTD_BASE, GPIO_PIN_7);
    TI PinMux
    // Unlock the Port Pin and Set the Commit Bit
    HWREG(GPIO_PORTD_BASE+GPIO_O_LOCK) = GPIO_LOCK_KEY;
    HWREG(GPIO_PORTD_BASE+GPIO_O_CR)   |= GPIO_PIN_7;
    HWREG(GPIO_PORTD_BASE+GPIO_O_LOCK) = 0x0;
    // Configure the GPIO Pin Mux for PD7
    // for USB0PFLT
  • Hello Lisa,
    Yes the TI PinMux code is the recommended code for use.
