RM41L232: LINport pins configured as GPIO
Part Number: RM41L232
Other Parts Discussed in Thread: HALCOGEN
Hi team,
I have been helping a customer try to get the LINport (LINRX and the LINTX) configured as a GPIO using HalCoGen and its not working out too well.
Does someone happen to have an example showing this?
I looked in the package locally at:
C:\ti\Hercules\HALCoGen\v04.07.00\examples\RM42x_41x
There unfortunately isn’t anything usable to help show this there.
Here is the latest from them, and what’s had me reach out to yall:
So I tried following the “example_rtiBlinky.c” creating a whole new project and following the directions in the example with the exception of referencing the “linPORT” instead of the “hetPORT1” and it does not seem to work.  I can control other pins such as the “spiPORT1” pins just fine following this example but the “linPORT” does not seem to respond or change the level of the pins.
Please let me know what you think about this.
Billy
  • Hello Billy,
    There is nothing special about the LIN pins. Simpy configure them as GPIO in Halcogen as shown below
    Once the source is generated, you would need to call the linInit function in main and then use the GPIO function to set and clear the bits associated with the LINTX and LIN RX pins.
    i.e., in main do the following
    main()
       linInit(); // initialize the LIN module; specifically, initializes LINTX and RX pins in non-funcitonal mode, DIR=output, Pullup enabled, no open drain, etc
    while(1)
            // Toggle LINTX pin
            gioSetBit (linPORT, PIN_LIN_TX);
            //Toggle LINRX pin
            gioSetBit (linPORT, PIN_LIN_RX);
     // ************* insert some delay or call gioSetBit from within an RTI interrupt after initializing and setting up to generate some sort of pattern on the LIN TX and RX pins
    Since the pin control registers of the LIN port only have the TX and RX pins in them with the rest being reserved, you should also be able to replicate the blinky example and call the port functions using the linPORT as the base address.
  • Thanks Chuck!
    That bit of extra help did it!
    -Billy
