RM57L843: CRC module with large memory areas
Part Number: RM57L843
I am using the CRC64 module for integrety test on files. For smaller files it works fine, but using larger files does not work as expected.
I want to split the memory areas int 32 KB blocks (or lesser) then i want the results of those as initialvector for the next calculation.
I don't see where to set the initialvector.
I am using the CRC module in semi mode and DMA access.
Someone any idea?
Thank you
  • Hello Daniel,
    I don't figure out the reason why the big file doesn't work. If you use more than 1 sectors, you need to provide the pre-calculated CRC values for each sectors.
  • Hello Daniel,
    Attached please find a CCS7 project for calculating CRC with semi-CPU and DMA. The data is read from flash starting at 0x0, and section size is 8160*32. You can change the project property for RM57 device.
    5483.TMS570LC4357_CRC.zip
  • Hello QJ,
    thanks for your quick response.
    My fault was or is probably in the DMA configuration.
    I had set the mode to frame transfer mode, which now I changed to block transfer mode.
    Your flash size in the example has got a fix size and will never changed. My files are dynamically in size and alignment. So i had to set the FRCNT and ELCNT also dynamically. But the filesize is not always divisible by 2, 4, 8, etc. What is the solution  here? Do I have to search the greatest divisor? Or shall I set the FRCNT to the filesize and the ELCNT to 1? Is it not possible to use sectors with different sizes? For example when I split a File with 150KB into three sectors with 2 times 64 KB and one time 26 KB. Below I have attached my sourcecode, thank you for your answer.
    uint64_t crcCalc(crcBASE_t *crc, uint32_t addr, uint32_t size){
        static uint32_t init;
        volatile uint64 u64Signature = 0;
        if( init _EQ_ 0){
            crcInit();
            init++;
        /* Enable DMA module : this brings DMA out of reset */
        dmaEnable();
        crcConfig_t sCrcParams;
        g_dmaCTRL g_dmaCTRLPKT;
     /* Configure DMA Control Packed (structure is part of dma.c) */
        g_dmaCTRLPKT.SADD      = addr;  /* initial source address */
        g_dmaCTRLPKT.DADD      = (uint32_t)(&(crcREG->PSA_SIGREGL1)); /* initial destination address */
        g_dmaCTRLPKT.CHCTRL    = 0ul; /* channel control */
        g_dmaCTRLPKT.RDSIZE    = ACCESS_64_BIT; /* read size */
        g_dmaCTRLPKT.WRSIZE    = ACCESS_64_BIT; /* write size */
        g_dmaCTRLPKT.FRCNT     = size; /* frame count */
        g_dmaCTRLPKT.ELCNT     = 1;   /* element count */
        g_dmaCTRLPKT.ELSOFFSET = 0ul << g_dmaCTRLPKT.RDSIZE; /* element source offset */
        g_dmaCTRLPKT.FRSOFFSET = 0ul << g_dmaCTRLPKT.RDSIZE; /* frame source offset */
        g_dmaCTRLPKT.ELDOFFSET = 0ul << g_dmaCTRLPKT.WRSIZE; /* element destination offset */
        g_dmaCTRLPKT.FRDOFFSET = 0ul << g_dmaCTRLPKT.WRSIZE; /* frame destination offset */
        g_dmaCTRLPKT.PORTASGN  = 1ul; /* Port A Read (Flash) - Port B Write (CRC) */
        g_dmaCTRLPKT.TTYPE     =  BLOCK_TRANSFER ; /* transfer type */
        g_dmaCTRLPKT.ADDMODERD = ADDR_INC1;     /* address mode read */
        g_dmaCTRLPKT.ADDMODEWR = ADDR_FIXED;     /* address mode write */
        g_dmaCTRLPKT.AUTOINIT  = AUTOINIT_OFF;     /* autoinit off */
        sCrcParams.crc_channel   = CRC_CH1;
        sCrcParams.mode          = CRC_SEMI_CPU;
        sCrcParams.pcount        = g_dmaCTRLPKT.ELCNT;
        sCrcParams.scount        = 1u;
        sCrcParams.wdg_preload   = 0u;
        sCrcParams.block_preload = 0u;
        crcChannelReset(crcREG, CRC_CH1);
        crcSetConfig(crcREG, &sCrcParams);
        /* Assign DMA Control Packet to Channel 0 */
        dmaSetCtrlPacket(DMA_CH0, g_dmaCTRLPKT);
        /* Trigger DMA Channel 0 s/w request */
        dmaSetChEnable(DMA_CH0, DMA_SW);
        while( (dmaREG->SWCHENAS & 1ul) | (crcREG->BUSY & 1ul) )
            /* Wait until DMA finished and CRC indicates block compressed */
        u64Signature = crcGetSectorSig(crcREG, CRC_CH1);
        /* Clear CH1_CCIT bit */
        crcREG->STATUS = CRC_CH1_CC;
    return u64Signature;
  • Hello Daniel,
    The access size is 64 bit (8 bytes). You can append 0s to the file to make the filesize divisible by 8. There is no problem to set FRCNT=filesize/8 and ELCNT=1. It's better to use the same size for all the sectors, but it is ok to use sectors with different size. With different sector size, you need to program different value to PCOUNT_REG1.
    sCrcParams.pcount = g_dmaCTRLPKT.ELCNT; should be .FRCNT
