Part Number: RM48L952
Other Parts Discussed in Thread: HALCOGEN
I have started to encounter a problem with my program if I try to run without the debugger (xds100v2) connected. Download a new program and everything appears OK, can debug and verify the behaviour of the prorgam as I have always done. Disconnect from the target while it is still running and everything remains OK. However, the minute I try to do a restart by cycling power on and off I cannot run the program, the MCU apperas to be in continual reset. If I connect while in this state and pause the debugger the device is stuck at prefetchEntry interrupt vector.
I would appreciate some guidance on isolating the root cause of this error., which registers to examine etc.
Jamie
