Part Number: RM57L843
Hi
I have two questions.
1)-What is the pull up / pull down resistor value by default? Should we consider, in the power sequence, can we assume the default resistor is attached with respect to it the microcontroller pins.
2)-EMIF clock is used in asynchronous/synchronous. What is the default value of EMIF clock used in the asynchronous communication? How is it calculated.
Regards;
