Hello Support,
When STCSCSCR is used to perform Self Test in STC1 by setting SELF_CHECK_KEY = 0x0A, then what should be the contents of STCSEGPLR register?
Should Segment 0 or Segment 1 be selected?
Thank you.
Pashan
Hello Support,
Thank you.
Pashan
Hi Pashan,
The signature compare selfcheck is recommended at application startup only. The selfcheck can be done for either segment 0/1 only or both.
1. Segment 0
a. Enable the SELF_CHECK_KEY and FAULT_INS in STCSCSCR register
b. Configure the STCSEGPLR to 1st interval of segment 0
c. Configure the RS_CNT bit 1 to 1
d. Check STC global status register and STCFSTAT register
e. Disable either or both the SELF_CHECK_KEY and FAULT_INS in STCSCSCR register
2. Segment 1
b. Configure the STCSEGPLR to 1st interval of segment 1
