Is there some dedicated IC that i can use or some controller which is fit for this job..Currently i have TM4C123 microcontroller.
And if some micro controller than what should i use to generate it like Timer,PWM etc.. and how to do that?
Further Explanation:
This Signal is given to a FMCW PLL which generate frequency depending on the value of 12 bit input... i want to produce a triangle(transmit) signal where frequency vary from 2.05Ghz to 2.3 Ghz.
All 0's = 2.05Ghz and All 1's = 2.3 Ghz...Where B=250Mhz and T=1-4 ms
So i need to generate a digital signal as mentioned in the post
