Part Number: EK-TM4C123GXL
I just ordered 5 EK-TM4C123GXL. from the TI store. I plugged in the first one to the USB port, it doesn't even light up at all. I tried a different USB port, I get the same result it doesn't power up.Two other boards,. I programmed them once with Keil, using a working software that I used with other boards. The programming went well the first time but failed the second time I tried to program them again. , I got the "could not initialize the target device", I tried to erase the flash by using the LM flash programmer. Build 1613, no luck at all. Can I send back those board for exchange?
Thank you
Hani
