Compiler/TMS570LS1114: When i build my TMS570LS114 C code project,there is no error display ,but can not generate the .out file?
Part Number: TMS570LS1114
Hi Guys:
  I used the CCS  Version: 6.0.1.00040 to build the C code project,but can not generate the .out file, and there is no error display.
and the result come from the building the Project,shown as below:
the detail about the console shown as below:
**** Build of configuration Debug for project Prj_DCAN_CS_01 ****
"c:\\ti\\ccsv6\\utils\\bin\\gmake" -k all
'Building file: ../Prj_DCAN_HAL_01/source/adc.c'
'Invoking: ARM Compiler'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/source/adc.pp" --obj_directory="Prj_DCAN_HAL_01/source"  "../Prj_DCAN_HAL_01/source/adc.c"
'Finished building: ../Prj_DCAN_HAL_01/source/adc.c'
'Building file: ../Prj_DCAN_HAL_01/source/can.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/source/can.pp" --obj_directory="Prj_DCAN_HAL_01/source"  "../Prj_DCAN_HAL_01/source/can.c"
'Finished building: ../Prj_DCAN_HAL_01/source/can.c'
'Building file: ../Prj_DCAN_HAL_01/source/dabort.asm'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/source/dabort.pp" --obj_directory="Prj_DCAN_HAL_01/source"  "../Prj_DCAN_HAL_01/source/dabort.asm"
'Finished building: ../Prj_DCAN_HAL_01/source/dabort.asm'
'Building file: ../Prj_DCAN_HAL_01/source/dcc.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/source/dcc.pp" --obj_directory="Prj_DCAN_HAL_01/source"  "../Prj_DCAN_HAL_01/source/dcc.c"
'Finished building: ../Prj_DCAN_HAL_01/source/dcc.c'
'Building file: ../Prj_DCAN_HAL_01/source/esm.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/source/esm.pp" --obj_directory="Prj_DCAN_HAL_01/source"  "../Prj_DCAN_HAL_01/source/esm.c"
'Finished building: ../Prj_DCAN_HAL_01/source/esm.c'
'Building file: ../Prj_DCAN_HAL_01/source/etpwm.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/source/etpwm.pp" --obj_directory="Prj_DCAN_HAL_01/source"  "../Prj_DCAN_HAL_01/source/etpwm.c"
'Finished building: ../Prj_DCAN_HAL_01/source/etpwm.c'
'Building file: ../Prj_DCAN_HAL_01/source/gio.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/source/gio.pp" --obj_directory="Prj_DCAN_HAL_01/source"  "../Prj_DCAN_HAL_01/source/gio.c"
'Finished building: ../Prj_DCAN_HAL_01/source/gio.c'
'Building file: ../Prj_DCAN_HAL_01/source/het.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/source/het.pp" --obj_directory="Prj_DCAN_HAL_01/source"  "../Prj_DCAN_HAL_01/source/het.c"
'Finished building: ../Prj_DCAN_HAL_01/source/het.c'
'Building file: ../Prj_DCAN_HAL_01/source/notification.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/source/notification.pp" --obj_directory="Prj_DCAN_HAL_01/source"  "../Prj_DCAN_HAL_01/source/notification.c"
'Finished building: ../Prj_DCAN_HAL_01/source/notification.c'
'Building file: ../Prj_DCAN_HAL_01/source/pinmux.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/source/pinmux.pp" --obj_directory="Prj_DCAN_HAL_01/source"  "../Prj_DCAN_HAL_01/source/pinmux.c"
'Finished building: ../Prj_DCAN_HAL_01/source/pinmux.c'
'Building file: ../Prj_DCAN_HAL_01/source/spi.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/source/spi.pp" --obj_directory="Prj_DCAN_HAL_01/source"  "../Prj_DCAN_HAL_01/source/spi.c"
'Finished building: ../Prj_DCAN_HAL_01/source/spi.c'
'Building file: ../Prj_DCAN_HAL_01/source/sys_core.asm'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/source/sys_core.pp" --obj_directory="Prj_DCAN_HAL_01/source"  "../Prj_DCAN_HAL_01/source/sys_core.asm"
'Finished building: ../Prj_DCAN_HAL_01/source/sys_core.asm'
'Building file: ../Prj_DCAN_HAL_01/source/sys_dma.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/source/sys_dma.pp" --obj_directory="Prj_DCAN_HAL_01/source"  "../Prj_DCAN_HAL_01/source/sys_dma.c"
'Finished building: ../Prj_DCAN_HAL_01/source/sys_dma.c'
'Building file: ../Prj_DCAN_HAL_01/source/sys_intvecs.asm'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/source/sys_intvecs.pp" --obj_directory="Prj_DCAN_HAL_01/source"  "../Prj_DCAN_HAL_01/source/sys_intvecs.asm"
'Finished building: ../Prj_DCAN_HAL_01/source/sys_intvecs.asm'
'Building file: ../Prj_DCAN_HAL_01/source/sys_main.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/source/sys_main.pp" --obj_directory="Prj_DCAN_HAL_01/source"  "../Prj_DCAN_HAL_01/source/sys_main.c"
"..\Prj_DCAN_HAL_01\source\..\my_header\../Pwm_application/Pwm_application.h", line 15: warning #734-D: array with incomplete element type is nonstandard
"..\Prj_DCAN_HAL_01\source\..\my_header\../Pwm_application/Pwm_application.h", line 15: warning #71-D: incomplete type is not allowed
"..\Prj_DCAN_HAL_01\source\..\my_header\../Pwm_application/Pwm_application.h", line 15: error #237: variable "PwmOut" was declared with a never-completed type
1 error detected in the compilation of "../Prj_DCAN_HAL_01/source/sys_main.c".
>> Compilation failure
gmake: *** [Prj_DCAN_HAL_01/source/sys_main.obj] Error 1
'Building file: ../Prj_DCAN_HAL_01/source/sys_mpu.asm'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/source/sys_mpu.pp" --obj_directory="Prj_DCAN_HAL_01/source"  "../Prj_DCAN_HAL_01/source/sys_mpu.asm"
'Finished building: ../Prj_DCAN_HAL_01/source/sys_mpu.asm'
'Building file: ../Prj_DCAN_HAL_01/source/sys_pcr.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/source/sys_pcr.pp" --obj_directory="Prj_DCAN_HAL_01/source"  "../Prj_DCAN_HAL_01/source/sys_pcr.c"
'Finished building: ../Prj_DCAN_HAL_01/source/sys_pcr.c'
'Building file: ../Prj_DCAN_HAL_01/source/sys_phantom.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/source/sys_phantom.pp" --obj_directory="Prj_DCAN_HAL_01/source"  "../Prj_DCAN_HAL_01/source/sys_phantom.c"
'Finished building: ../Prj_DCAN_HAL_01/source/sys_phantom.c'
'Building file: ../Prj_DCAN_HAL_01/source/sys_pmm.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/source/sys_pmm.pp" --obj_directory="Prj_DCAN_HAL_01/source"  "../Prj_DCAN_HAL_01/source/sys_pmm.c"
'Finished building: ../Prj_DCAN_HAL_01/source/sys_pmm.c'
'Building file: ../Prj_DCAN_HAL_01/source/sys_pmu.asm'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/source/sys_pmu.pp" --obj_directory="Prj_DCAN_HAL_01/source"  "../Prj_DCAN_HAL_01/source/sys_pmu.asm"
'Finished building: ../Prj_DCAN_HAL_01/source/sys_pmu.asm'
'Building file: ../Prj_DCAN_HAL_01/source/sys_selftest.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/source/sys_selftest.pp" --obj_directory="Prj_DCAN_HAL_01/source"  "../Prj_DCAN_HAL_01/source/sys_selftest.c"
'Finished building: ../Prj_DCAN_HAL_01/source/sys_selftest.c'
'Building file: ../Prj_DCAN_HAL_01/source/sys_startup.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/source/sys_startup.pp" --obj_directory="Prj_DCAN_HAL_01/source"  "../Prj_DCAN_HAL_01/source/sys_startup.c"
'Finished building: ../Prj_DCAN_HAL_01/source/sys_startup.c'
'Building file: ../Prj_DCAN_HAL_01/source/sys_vim.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/source/sys_vim.pp" --obj_directory="Prj_DCAN_HAL_01/source"  "../Prj_DCAN_HAL_01/source/sys_vim.c"
'Finished building: ../Prj_DCAN_HAL_01/source/sys_vim.c'
'Building file: ../Prj_DCAN_HAL_01/source/system.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/source/system.pp" --obj_directory="Prj_DCAN_HAL_01/source"  "../Prj_DCAN_HAL_01/source/system.c"
'Finished building: ../Prj_DCAN_HAL_01/source/system.c'
'Building file: ../Prj_DCAN_HAL_01/resolver/resolver.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/resolver/resolver.pp" --obj_directory="Prj_DCAN_HAL_01/resolver"  "../Prj_DCAN_HAL_01/resolver/resolver.c"
'Finished building: ../Prj_DCAN_HAL_01/resolver/resolver.c'
'Building file: ../Prj_DCAN_HAL_01/pospe_flt/POSPE_FLT.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/pospe_flt/POSPE_FLT.pp" --obj_directory="Prj_DCAN_HAL_01/pospe_flt"  "../Prj_DCAN_HAL_01/pospe_flt/POSPE_FLT.c"
"../Prj_DCAN_HAL_01/pospe_flt/POSPE_FLT.c", line 123: warning #552-D: variable "AbsSpd" was set but never used
'Finished building: ../Prj_DCAN_HAL_01/pospe_flt/POSPE_FLT.c'
'Building file: ../Prj_DCAN_HAL_01/my_header/myfastloopfuncfile.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/my_header/myfastloopfuncfile.pp" --obj_directory="Prj_DCAN_HAL_01/my_header"  "../Prj_DCAN_HAL_01/my_header/myfastloopfuncfile.c"
'Finished building: ../Prj_DCAN_HAL_01/my_header/myfastloopfuncfile.c'
'Building file: ../Prj_DCAN_HAL_01/my_header/myfocirq.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/my_header/myfocirq.pp" --obj_directory="Prj_DCAN_HAL_01/my_header"  "../Prj_DCAN_HAL_01/my_header/myfocirq.c"
"..\Prj_DCAN_HAL_01\my_header\myglobaldefine.h", line 74: error #115: function "faultDetection" was referenced but not defined
1 error detected in the compilation of "../Prj_DCAN_HAL_01/my_header/myfocirq.c".
>> Compilation failure
gmake: *** [Prj_DCAN_HAL_01/my_header/myfocirq.obj] Error 1
'Building file: ../Prj_DCAN_HAL_01/my_header/mygetvariable.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/my_header/mygetvariable.pp" --obj_directory="Prj_DCAN_HAL_01/my_header"  "../Prj_DCAN_HAL_01/my_header/mygetvariable.c"
'Finished building: ../Prj_DCAN_HAL_01/my_header/mygetvariable.c'
'Building file: ../Prj_DCAN_HAL_01/my_header/mymainfunctions.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/my_header/mymainfunctions.pp" --obj_directory="Prj_DCAN_HAL_01/my_header"  "../Prj_DCAN_HAL_01/my_header/mymainfunctions.c"
'Finished building: ../Prj_DCAN_HAL_01/my_header/mymainfunctions.c'
'Building file: ../Prj_DCAN_HAL_01/my_header/mymainwhileloop.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/my_header/mymainwhileloop.pp" --obj_directory="Prj_DCAN_HAL_01/my_header"  "../Prj_DCAN_HAL_01/my_header/mymainwhileloop.c"
'Finished building: ../Prj_DCAN_HAL_01/my_header/mymainwhileloop.c'
'Building file: ../Prj_DCAN_HAL_01/my_header/myslowloopfuncfile.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/my_header/myslowloopfuncfile.pp" --obj_directory="Prj_DCAN_HAL_01/my_header"  "../Prj_DCAN_HAL_01/my_header/myslowloopfuncfile.c"
'Finished building: ../Prj_DCAN_HAL_01/my_header/myslowloopfuncfile.c'
'Building file: ../Prj_DCAN_HAL_01/my_header/mystatealignfuncfile.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/my_header/mystatealignfuncfile.pp" --obj_directory="Prj_DCAN_HAL_01/my_header"  "../Prj_DCAN_HAL_01/my_header/mystatealignfuncfile.c"
'Finished building: ../Prj_DCAN_HAL_01/my_header/mystatealignfuncfile.c'
'Building file: ../Prj_DCAN_HAL_01/my_header/mystatecalibfuncfile.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/my_header/mystatecalibfuncfile.pp" --obj_directory="Prj_DCAN_HAL_01/my_header"  "../Prj_DCAN_HAL_01/my_header/mystatecalibfuncfile.c"
'Finished building: ../Prj_DCAN_HAL_01/my_header/mystatecalibfuncfile.c'
'Building file: ../Prj_DCAN_HAL_01/my_header/mystatefaultfuncfile.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/my_header/mystatefaultfuncfile.pp" --obj_directory="Prj_DCAN_HAL_01/my_header"  "../Prj_DCAN_HAL_01/my_header/mystatefaultfuncfile.c"
'Finished building: ../Prj_DCAN_HAL_01/my_header/mystatefaultfuncfile.c'
'Building file: ../Prj_DCAN_HAL_01/my_header/mystateinitfunfile.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/my_header/mystateinitfunfile.pp" --obj_directory="Prj_DCAN_HAL_01/my_header"  "../Prj_DCAN_HAL_01/my_header/mystateinitfunfile.c"
'Finished building: ../Prj_DCAN_HAL_01/my_header/mystateinitfunfile.c'
'Building file: ../Prj_DCAN_HAL_01/my_header/mystatereadyfuncfile.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/my_header/mystatereadyfuncfile.pp" --obj_directory="Prj_DCAN_HAL_01/my_header"  "../Prj_DCAN_HAL_01/my_header/mystatereadyfuncfile.c"
'Finished building: ../Prj_DCAN_HAL_01/my_header/mystatereadyfuncfile.c'
'Building file: ../Prj_DCAN_HAL_01/my_header/mystaterunfunfile.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/my_header/mystaterunfunfile.pp" --obj_directory="Prj_DCAN_HAL_01/my_header"  "../Prj_DCAN_HAL_01/my_header/mystaterunfunfile.c"
"..\Prj_DCAN_HAL_01\my_header\../Pwm_application/Pwm_application.h", line 15: warning #734-D: array with incomplete element type is nonstandard
"..\Prj_DCAN_HAL_01\my_header\../Pwm_application/Pwm_application.h", line 15: warning #71-D: incomplete type is not allowed
"../Prj_DCAN_HAL_01/my_header/mystaterunfunfile.c", line 21: warning #552-D: variable "getFcnStatus" was set but never used
"../Prj_DCAN_HAL_01/my_header/mystaterunfunfile.c", line 65: warning #179-D: variable "iqreqbuf" was declared but never referenced
"../Prj_DCAN_HAL_01/my_header/mystaterunfunfile.c", line 66: warning #179-D: variable "idreq_sum" was declared but never referenced
"../Prj_DCAN_HAL_01/my_header/mystaterunfunfile.c", line 66: warning #179-D: variable "iqreq_sum" was declared but never referenced
"../Prj_DCAN_HAL_01/my_header/mystaterunfunfile.c", line 68: warning #179-D: variable "iqreqlimit" was declared but never referenced
"../Prj_DCAN_HAL_01/my_header/mystaterunfunfile.c", line 69: warning #179-D: variable "idreqnum" was declared but never referenced
"../Prj_DCAN_HAL_01/my_header/mystaterunfunfile.c", line 69: warning #179-D: variable "idreqnum1" was declared but never referenced
"../Prj_DCAN_HAL_01/my_header/mystaterunfunfile.c", line 69: warning #179-D: variable "iqreqnum" was declared but never referenced
"../Prj_DCAN_HAL_01/my_header/mystaterunfunfile.c", line 69: warning #179-D: variable "iqreqnum1" was declared but never referenced
"../Prj_DCAN_HAL_01/my_header/mystaterunfunfile.c", line 70: warning #552-D: variable "pmtpaidq" was set but never used
"../Prj_DCAN_HAL_01/my_header/mystaterunfunfile.c", line 157: warning #179-D: variable "udbuf" was declared but never referenced
"../Prj_DCAN_HAL_01/my_header/mystaterunfunfile.c", line 158: warning #179-D: variable "uqbuf" was declared but never referenced
"../Prj_DCAN_HAL_01/my_header/mystaterunfunfile.c", line 166: warning #179-D: variable "udfilter_sum" was declared but never referenced
"../Prj_DCAN_HAL_01/my_header/mystaterunfunfile.c", line 166: warning #179-D: variable "uqfilter_sum" was declared but never referenced
"../Prj_DCAN_HAL_01/my_header/mystaterunfunfile.c", line 178: warning #552-D: variable "usedid_kp" was set but never used
"../Prj_DCAN_HAL_01/my_header/mystaterunfunfile.c", line 178: warning #179-D: variable "usedid_ki" was declared but never referenced
"../Prj_DCAN_HAL_01/my_header/mystaterunfunfile.c", line 181: warning #179-D: variable "iderrornum" was declared but never referenced
"../Prj_DCAN_HAL_01/my_header/mystaterunfunfile.c", line 181: warning #179-D: variable "iderrornum1" was declared but never referenced
"../Prj_DCAN_HAL_01/my_header/mystaterunfunfile.c", line 181: warning #179-D: variable "iqerrornum" was declared but never referenced
"../Prj_DCAN_HAL_01/my_header/mystaterunfunfile.c", line 181: warning #179-D: variable "iqerrornum1" was declared but never referenced
"../Prj_DCAN_HAL_01/my_header/mystaterunfunfile.c", line 182: warning #179-D: variable "udi" was declared but never referenced
"../Prj_DCAN_HAL_01/my_header/mystaterunfunfile.c", line 182: warning #179-D: variable "udi1" was declared but never referenced
"../Prj_DCAN_HAL_01/my_header/mystaterunfunfile.c", line 182: warning #179-D: variable "uqi" was declared but never referenced
"../Prj_DCAN_HAL_01/my_header/mystaterunfunfile.c", line 182: warning #179-D: variable "uqi1" was declared but never referenced
"../Prj_DCAN_HAL_01/my_header/mystaterunfunfile.c", line 183: warning #179-D: variable "iderror_sum" was declared but never referenced
"../Prj_DCAN_HAL_01/my_header/mystaterunfunfile.c", line 183: warning #179-D: variable "iqerror_sum" was declared but never referenced
"..\Prj_DCAN_HAL_01\my_header\../Pwm_application/Pwm_application.h", line 15: error #237: variable "PwmOut" was declared with a never-completed type
1 error detected in the compilation of "../Prj_DCAN_HAL_01/my_header/mystaterunfunfile.c".
>> Compilation failure
gmake: *** [Prj_DCAN_HAL_01/my_header/mystaterunfunfile.obj] Error 1
'Building file: ../Prj_DCAN_HAL_01/motor_structure/sub.c/Estimation_Para.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/motor_structure/sub.c/Estimation_Para.pp" --obj_directory="Prj_DCAN_HAL_01/motor_structure/sub.c"  "../Prj_DCAN_HAL_01/motor_structure/sub.c/Estimation_Para.c"
'Finished building: ../Prj_DCAN_HAL_01/motor_structure/sub.c/Estimation_Para.c'
'Building file: ../Prj_DCAN_HAL_01/motor_structure/sub.c/Stateflow.c'
'Invoking: ARM Compiler'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/motor_structure/sub.c/Stateflow.pp" --obj_directory="Prj_DCAN_HAL_01/motor_structure/sub.c"  "../Prj_DCAN_HAL_01/motor_structure/sub.c/Stateflow.c"
'Finished building: ../Prj_DCAN_HAL_01/motor_structure/sub.c/Stateflow.c'
'Building file: ../Prj_DCAN_HAL_01/motor_structure/sub.c/foc_algorithm.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/motor_structure/sub.c/foc_algorithm.pp" --obj_directory="Prj_DCAN_HAL_01/motor_structure/sub.c"  "../Prj_DCAN_HAL_01/motor_structure/sub.c/foc_algorithm.c"
"../Prj_DCAN_HAL_01/motor_structure/sub.c/foc_algorithm.c", line 416: warning #552-D: variable "RtbMidSaturPara" was set but never used
'Finished building: ../Prj_DCAN_HAL_01/motor_structure/sub.c/foc_algorithm.c'
'Building file: ../Prj_DCAN_HAL_01/math_function/sub_c/MLIB_Mul.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/math_function/sub_c/MLIB_Mul.pp" --obj_directory="Prj_DCAN_HAL_01/math_function/sub_c"  "../Prj_DCAN_HAL_01/math_function/sub_c/MLIB_Mul.c"
'Finished building: ../Prj_DCAN_HAL_01/math_function/sub_c/MLIB_Mul.c'
'Building file: ../Prj_DCAN_HAL_01/math_function/sub_c/Q_Format.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/math_function/sub_c/Q_Format.pp" --obj_directory="Prj_DCAN_HAL_01/math_function/sub_c"  "../Prj_DCAN_HAL_01/math_function/sub_c/Q_Format.c"
'Finished building: ../Prj_DCAN_HAL_01/math_function/sub_c/Q_Format.c'
'Building file: ../Prj_DCAN_HAL_01/dischg_prechg/dischg_prechg.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/dischg_prechg/dischg_prechg.pp" --obj_directory="Prj_DCAN_HAL_01/dischg_prechg"  "../Prj_DCAN_HAL_01/dischg_prechg/dischg_prechg.c"
'Finished building: ../Prj_DCAN_HAL_01/dischg_prechg/dischg_prechg.c'
'Building file: ../Prj_DCAN_HAL_01/can_pack_unpack/sub.c/CAN_Pack_Unpack.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/can_pack_unpack/sub.c/CAN_Pack_Unpack.pp" --obj_directory="Prj_DCAN_HAL_01/can_pack_unpack/sub.c"  "../Prj_DCAN_HAL_01/can_pack_unpack/sub.c/CAN_Pack_Unpack.c"
'Finished building: ../Prj_DCAN_HAL_01/can_pack_unpack/sub.c/CAN_Pack_Unpack.c'
'Building file: ../Prj_DCAN_HAL_01/can_pack_unpack/sub.c/Glab_Sig_Output.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/can_pack_unpack/sub.c/Glab_Sig_Output.pp" --obj_directory="Prj_DCAN_HAL_01/can_pack_unpack/sub.c"  "../Prj_DCAN_HAL_01/can_pack_unpack/sub.c/Glab_Sig_Output.c"
'Finished building: ../Prj_DCAN_HAL_01/can_pack_unpack/sub.c/Glab_Sig_Output.c'
'Building file: ../Prj_DCAN_HAL_01/can_pack_unpack/sub.c/can_application.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/can_pack_unpack/sub.c/can_application.pp" --obj_directory="Prj_DCAN_HAL_01/can_pack_unpack/sub.c"  "../Prj_DCAN_HAL_01/can_pack_unpack/sub.c/can_application.c"
'Finished building: ../Prj_DCAN_HAL_01/can_pack_unpack/sub.c/can_application.c'
'Building file: ../Prj_DCAN_HAL_01/adc_application/temp/igbttemperature.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/adc_application/temp/igbttemperature.pp" --obj_directory="Prj_DCAN_HAL_01/adc_application/temp"  "../Prj_DCAN_HAL_01/adc_application/temp/igbttemperature.c"
'Finished building: ../Prj_DCAN_HAL_01/adc_application/temp/igbttemperature.c'
'Building file: ../Prj_DCAN_HAL_01/adc_application/temp/motortemperature.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/adc_application/temp/motortemperature.pp" --obj_directory="Prj_DCAN_HAL_01/adc_application/temp"  "../Prj_DCAN_HAL_01/adc_application/temp/motortemperature.c"
"../Prj_DCAN_HAL_01/adc_application/temp/motortemperature.c", line 21: warning #552-D: variable "motmaxtemptmid" was set but never used
"../Prj_DCAN_HAL_01/adc_application/temp/motortemperature.c", line 21: warning #552-D: variable "motmintemptmid" was set but never used
"../Prj_DCAN_HAL_01/adc_application/temp/motortemperature.c", line 21: warning #552-D: variable "motmaxRtmid" was set but never used
"../Prj_DCAN_HAL_01/adc_application/temp/motortemperature.c", line 21: warning #552-D: variable "motminRtmid" was set but never used
'Finished building: ../Prj_DCAN_HAL_01/adc_application/temp/motortemperature.c'
'Building file: ../Prj_DCAN_HAL_01/adc_application/adc_application.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/adc_application/adc_application.pp" --obj_directory="Prj_DCAN_HAL_01/adc_application"  "../Prj_DCAN_HAL_01/adc_application/adc_application.c"
"../Prj_DCAN_HAL_01/adc_application/adc_application.c", line 157: warning #179-D: variable "sumAraw" was declared but never referenced
"../Prj_DCAN_HAL_01/adc_application/adc_application.c", line 157: warning #179-D: variable "sumBraw" was declared but never referenced
"../Prj_DCAN_HAL_01/adc_application/adc_application.c", line 157: warning #179-D: variable "sumCraw" was declared but never referenced
"../Prj_DCAN_HAL_01/adc_application/adc_application.c", line 157: warning #179-D: variable "transpa1" was declared but never referenced
"../Prj_DCAN_HAL_01/adc_application/adc_application.c", line 158: warning #179-D: variable "OBSER" was declared but never referenced
"../Prj_DCAN_HAL_01/adc_application/adc_application.c", line 160: warning #552-D: variable "obser1" was set but never used
"../Prj_DCAN_HAL_01/adc_application/adc_application.c", line 160: warning #552-D: variable "obser2" was set but never used
"../Prj_DCAN_HAL_01/adc_application/adc_application.c", line 160: warning #179-D: variable "obser3" was declared but never referenced
"../Prj_DCAN_HAL_01/adc_application/adc_application.c", line 287: warning #179-D: variable "upfilterRawUdccomp" was declared but never referenced
"../Prj_DCAN_HAL_01/adc_application/adc_application.c", line 343: warning #179-D: variable "maxmotormid1" was declared but never referenced
'Finished building: ../Prj_DCAN_HAL_01/adc_application/adc_application.c'
'Building file: ../Prj_DCAN_HAL_01/adc_application/myadcisr.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/adc_application/myadcisr.pp" --obj_directory="Prj_DCAN_HAL_01/adc_application"  "../Prj_DCAN_HAL_01/adc_application/myadcisr.c"
'Finished building: ../Prj_DCAN_HAL_01/adc_application/myadcisr.c'
'Building file: ../Prj_DCAN_HAL_01/Pwm_application/Pwm_application.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/Pwm_application/Pwm_application.pp" --obj_directory="Prj_DCAN_HAL_01/Pwm_application"  "../Prj_DCAN_HAL_01/Pwm_application/Pwm_application.c"
"..\Prj_DCAN_HAL_01\Pwm_application\../Pwm_application/Pwm_application.h", line 15: warning #734-D: array with incomplete element type is nonstandard
"..\Prj_DCAN_HAL_01\Pwm_application\../Pwm_application/Pwm_application.h", line 15: warning #71-D: incomplete type is not allowed
'Finished building: ../Prj_DCAN_HAL_01/Pwm_application/Pwm_application.c'
'Building file: ../Prj_DCAN_HAL_01/ErrorCode/ErrorCode.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/ErrorCode/ErrorCode.pp" --obj_directory="Prj_DCAN_HAL_01/ErrorCode"  "../Prj_DCAN_HAL_01/ErrorCode/ErrorCode.c"
'Finished building: ../Prj_DCAN_HAL_01/ErrorCode/ErrorCode.c'
'Building file: ../Prj_DCAN_HAL_01/AMMCLIB/filter_C/filter_math.c'
"c:/ti/ccsv6/tools/compiler/arm_5.1.6/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi --include_path="c:/ti/ccsv6/tools/compiler/arm_5.1.6/include" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/can_pack_unpack/sub.h" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/include" --include_path="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/motor_structure/sub.h" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/AMMCLIB" --include_path="D:/TMS570LS/Prj_DCAN_CS_02/Prj_DCAN_CS_01/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/algorithm_V1.1.9/include" --preinclude="C:/INV_code1215/Prj_DCAN_CS_12/Prj_DCAN_CS_10/Prj_DCAN_CS_01/Prj_DCAN_HAL_01/my_header/mymainfunctions.h" -g --display_error_number --diag_warning=225 --diag_wrap=off --enum_type=packed --preproc_with_compile --preproc_dependency="Prj_DCAN_HAL_01/AMMCLIB/filter_C/filter_math.pp" --obj_directory="Prj_DCAN_HAL_01/AMMCLIB/filter_C"  "../Prj_DCAN_HAL_01/AMMCLIB/filter_C/filter_math.c"
'Finished building: ../Prj_DCAN_HAL_01/AMMCLIB/filter_C/filter_math.c'
gmake: Target `all' not remade because of errors.
**** Build Finished ****
I do not  know how to solve it! Who can help me ?
  • The error is in the compilation of the sys_main.c file, as per the log you posted.
    "..\Prj_DCAN_HAL_01\source\..\my_header\../Pwm_application/Pwm_application.h", line 15: warning #734-D: array with incomplete element type is nonstandard
    "..\Prj_DCAN_HAL_01\source\..\my_header\../Pwm_application/Pwm_application.h", line 15: warning #71-D: incomplete type is not allowed
    "..\Prj_DCAN_HAL_01\source\..\my_header\../Pwm_application/Pwm_application.h", line 15: error #237: variable "PwmOut" was declared with a never-completed type
    1 error detected in the compilation of "../Prj_DCAN_HAL_01/source/sys_main.c".
    >> Compilation failure
    gmake: *** [Prj_DCAN_HAL_01/source/sys_main.obj] Error 1
    It is most likely due to a typo on line 15 of the Pwm_application.h file.
